91 Toyota 2.4D with black Exhaust Smoke
Submitted: Sunday, Jun 22, 2003 at 17:44
ThreadID: 5595 Views:2854 Replies:4 FollowUps:1
Diesel Warriors,
I have a 91 Toyota Hilux with a 2.4D engine with 150K/Km. In the past few months, my engine bellows large amounts of black smoke out of the exhaust under acceleration. I know diesel engines let out black smoke under acceleration, but this black cloud isn't normal. While the engine is idling, black smoke is still coming out of the exhaust, but not as bad. I live in Japan and the language barrier is a problem to explain with mechanics. Are there any suggestions.
CJ
Reply By: Member - JEFF - Sunday, Jun 22, 2003 at 18:35
G'DAY MATE ,
I ALSO HAVE A 2.4 DIESEL, SOUNDS LIKE YOU NEED A BIG INJECTOR CLEAN REAL SOON
GOOD LUCK IN JAPAN
JEFF
AnswerID: 23217
Reply By: diamond (bendigo) - Sunday, Jun 22, 2003 at 18:43
gday choward
sounds a lot like your injectors as said above.
looking foward to september(landcruiser park/fraser island)
AnswerID: 23219
Reply By: CHoward - Sunday, Jun 22, 2003 at 21:43
Thanks for responding, I will have the injectors cleaned and see how that does the trick. Is it possible that I got some bad gas and caused the injectors to go sour?
CJ
AnswerID: 23244
Follow Up By: Truckster (Vic) - Monday, Jun 23, 2003 at 00:09
150,000klms if they havent been done, then they are due for it anyway.
1 bad load of fuel, I would hesitate to think that would cause the problem. but anything is possible these days.
FollowupID: 15448
Reply By: colin - Wednesday, Jun 25, 2003 at 15:24
I would suggest first replace the fuel and air filters and put a good dose of fuel conditioner, and may be some one has turned the fuel up on the pump. Col
AnswerID: 23483
