Re: Dust in Caravan
Submitted: Sunday, Mar 30, 2008 at 16:47
Elross (WA)
Thread 56000. Thanks guys for all your info could John give me more information and anyone else who has a dust prevention fan in their caravan.
Reply By: Andrew from Vivid Adventures - Sunday, Mar 30, 2008 at 17:33
I have a fan in my trailer for that purpose - works a treat.
Gallery here
You can see the filtered inlet and the filtered outlet at the rear (you can't see the filter which is underneath) if you look down the images. It was added after manufacture, so you can't see it on the first images.
It uses a high volume fan driven off the trailer battery - makes quite a racket. I have a switch for it in the front tool-box and can turn it off and on.
PS. the trailer's for sale so I that's why I have a gallery - I am getting one similar but slightly larger.
295614
Follow Up By: Elross (WA) - Tuesday, Apr 01, 2008 at 01:32
Thanks Andrew your set up looked good.
We are having problems deciding what size fan we would need for a 19ftvan to make sure the psi was sufficient to stop the dust. Its very hard to work out with different vents etc in the van the the size fan we will need.
561945
