AnswerID: 295995 Submitted: Tuesday, Apr 01, 2008 at 18:24
Member - Doug T (FNQ)
replied:
Except for a small difference in the flattening term, the reference ellipsoid used with WGS84 is essentially the same as the Geodetic Reference System 1980 (GRS80) ellipsoid used with ITRF and hence GDA94.Given that the ITRF and WGS84 reference frames are also very closely aligned, for most practical purposes GDA94
and WGS84 coordinates can be considered the same and no transformation is required.In other words, when comparing GDA, WGS & ITRF datums, keep in mind that GDA94 coordinates are fixed as at the 1st January 1994 (epoch 1994.0) and that the
Australian plate is drifting in a north-easterly direction about seven centimetres per year. If we were to re-compute GDA now, the coordinates would about half a metre different.
 Click Image to Enlarge |
| Doug & Dusty
Along the Gibbie Creek Track
Gregory National Park |
Reply 1 of 5
