AnswerID: 296193 Submitted: Wednesday, Apr 02, 2008 at 18:58
Scrubcat
replied:
G`Day Nick,
I have just fitted a 12v/240v LCD TV/DVD in my van ,cost $295.00
from Coles, same TV without the built in DVD is about $100.00 less. I modified a Computer Monitor bracket ( $3.00 from the recycle yard) and mounted TV to it so it can be viewed from just about anywhere in the van, TV can be removed and taken outside if desired.
For an antenna I bought a c/van one from Bunnings (about $50.00)I modified it so it was held part way along the boom instead of at the end, when it was mounted at the end the boom bent because the flimsy boom material won`t hold the weight . I fitted a short section of Aluminium tube to the vans rear bumper into which fits 3 telescopic sections of aluminium tube
which has the antenna on top . The height is about 2 meters above the vans roof. The joins are held with those plastic doovers with a bolt and wing nut that are used on telescopic annex/tent poles. All up cost, Less than $400.00 plus my time, and it works fine. Personally I don`t want TV while I am out `n`about but it is an SWMABO requirement.
Check it out,
Scrubcat
Reply 6 of 7
