Site Search
Section Image
Brake Pedal not returning home LC 100
Submitted: Wednesday, Apr 02, 2008 at 15:01
Treading Lightly
Hi, Is this a common problem.
On occasions the brake pedal does not return fully home therefore still applying a slight brake force. To remedy I have to put my foot under the pedal and pull up.
JD
Life is to good to be dead.
ThreadID: 56192 Replies: 3
Views: 373 FollowUps: 2
AnswerID: 296154   Submitted: Wednesday, Apr 02, 2008 at 15:55
howesy replied:
I have seen it before in a car and it may not be the same cause but in his the rubbers in the master cylinder were letting fluid past.
Undo the thing and pull it slightly away from the booster and see if its wet in the back of it. There should be enough flex in the lines so you dont have to undo them.
Reply 1 of 3
AnswerID: 296159   Submitted: Wednesday, Apr 02, 2008 at 16:12
Member - Phil G (SA) replied:
Do you know what brake fluid has been used during the life of the vehicle?
It is possible that the seals in your brake master cylinder have swollen from the use of DOT4 fluid.
Mt Finke
Click Image to Enlarge
LandCruiser HDJ79
Reply 2 of 3
FollowupID: 562350   Submitted: Thursday, Apr 03, 2008 at 06:40
Treading Lightly posted:
Thanks for info Phil,
Toyota have done all service work, only done 70Ks.
JD
AnswerID: 296229   Submitted: Wednesday, Apr 02, 2008 at 19:57
Derek from Affordable Batteries & Radiators replied:
It is a common problem.
Toyota have a spring recall and updated spring on the '99 to '01 series.
Not sure of the exact models or dates but had mine done about a year ago.
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 3 of 3
FollowupID: 562351   Submitted: Thursday, Apr 03, 2008 at 06:41
Thanks Derek,
I will ring Toyota today and make inquires.
JD
