AnswerID: 296176 Submitted: Wednesday, Apr 02, 2008 at 17:23
feral
replied:
This is the only one you should get.....
Digimatch VHF/UHF Economy 7 Element Receives Band 3, 4, and 5 (Channel 6-12 and 28-69)
LT3172 - Digimatch VHF/UHF Economy 7 Element
Receives Band 3, 4, and 5 (ch 6-12 and 28-69)
Features:
Perfect for Caravans or space-conscious metropolitan areas
Designed to enable positions in all horizontal, vertical or horiz/vert. polarities
Suitable for all transmitters across
Australia
High Performance
Heavy Duty construction
Stainless Steel connection screws
Black UV resistant plastics
Boom length: 720mm
Max. width: 880mm
Supplied in stout, compact cardboard packaging
Powder coated boom (blue) QTY
1+ $69.95
2+ $62.95
5+ $55.95
Jaycar or Dick Smith should have these in stock.
They are the best allround performer.
Cheers.
Reply 3 of 8
FollowupID: 562354 Submitted:
Thursday, Apr 03, 2008 at 07:03
AdlelaideGeorge posted:
That may be good - bet this is better:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
12V Active Colour Antenna UHF/VHF/FM
Ideal for caravans, cars
camping and houses without 240VAC mains.
The antenna contains a built-in amplifier that operates from 12VDC. It can be powered from the vehicles battery and/or use it at home with the optional AC mains adaptor (MP3002). The antenna has telescopic dipoles at the rear for fine-tuning your reception, while the amplifier has a built in splitter for a second TV antenna. Supplied with a 6M coaxial lead with plugs, and a 12V power lead.
Specifications:
22-24dB gain
12VDC 100mA power source, 340(W) x 375(L) x 55(D)mm size.
QTY
1+ $49.95
2+ $44.90
5+ $39.90
from Jaycar electronics
Happy days
George
FollowUp 2 of 2
