AnswerID: 296567 Submitted: Friday, Apr 04, 2008 at 07:50
Redback
replied:
Cas, this is my setup, it's simple, easy to use and setup and i don't have or need a generator.
I have a 75AH deepcycle battery in the camper, that is charged via the car when moving, through an Anderson plug that runs an Arrid smart charger connected to the battery.
I use my 20 watt panel during the day when camped to top up the camper battery, i have 3 lights in the camper and the water pump and a 3 way running on gas when camped, so not alot of power used, the lights only use 1AH max.
If it's overcast, i top up the camper battery using an inverter to run a 240 volt battery charger and run it overnight off the second battery in the car, (YOU MUST HAVE A DUAL BATTERY SYSTEM FOR THIS)this isn't the most efficant way to do it but it works and i go for a short drive in the morning to re-charge my second battery.
My system;
1 20Watt solar panel
1 300watt inverter
1 Arlec 8 amp 240 watt charger
SC40 Traxide Tronics dual battery controller & Fullriver 60AH deepcycle batt (in the car)
This works for us and has done for 4 years now, 2 years in our current vehicle, we can camp in the one place for 9 days (longest we have camped at one place) so we could probably go for longer.
If like other you are running a 12v
fridge in the camper then you will need a better system and probably the gennie would need to be there as a backup, the TV maybe the thing that uses the most power, but as we don't have one i can't tell you how much.
Hope this helps, try to keep it simple and you'll have no problems.
Baz.
Baz.
1 Arrid Smart charger & 75AH deepcycle battery (in the camper)
Reply 7 of 7
