tappet clearances
Submitted: Thursday, Jun 26, 2003 at 22:53
ThreadID: 5688 Views:1786 Replies:2 FollowUps:2
Hi, I would like to know what the tappet clearances are for my 2002 4.2lt turbo diesel ST Patrol. Both inlet and exhaust.
Reply By: Member - Cocka - Friday, Jun 27, 2003 at 22:36
Can you get a copy of Gregory's workshop manual from your local friendly sparts shop. If your doing tappets it will give you lots of other info as well for the future.Carpe Diem
AnswerID: 23694
Follow Up By: GaryInOz (Vic) - Friday, Jun 27, 2003 at 22:56
2002 should be under warranty. Wouldn't touch it unless absolutely necessary. Warranty only covers you if the work is done by a licenced mechanic. "Home job" may void warranty unless done in extreme emergency (out in the stix).
FollowupID: 15861
Follow Up By: Member - Cocka - Tuesday, Jul 01, 2003 at 23:09
Gary absolutely right. I didn't pay attention to the 2002 bit of the Q.
However the owning of the book is still a good idea.Carpe Diem
FollowupID: 16134
Reply By: Martyn (WA) - Friday, Jun 27, 2003 at 23:00
John,
To adjust the tappets, get number six cylinder valves rocking mark the valves from the front one to twelve, number one at the front of course and adjust the tappets 1,2,4,5,8 & 9 with a 0.35 mm feeler blade, turn the engine 360 degrees now the valves on number one cylinder should be rocking adjust valves 3,6,7,10,11 & 12 again with a 0.35 mm feeler blade. Hope this helps. Keep the shiny side up
AnswerID: 23696
