One bright and one dull headlight..
Submitted: Monday, Jun 30, 2003 at 14:43
ThreadID: 5742 Views:4879 Replies:6 FollowUps:0
Does anyone know why I would have one bright (normal) and one dull headlight on low beam on my Excel? I've noticed this on other vehicles before but never had it happen to me. Any suggestions greatly appreciated.
Reply By: Ray - Monday, Jun 30, 2003 at 15:01
Three things to check
Check the globe to make sure the two fillaments are not touching
Check that only one beam is being supplied with power at any one time
Check that the earth terminal is clean and secure for that lamp
AnswerID: 23856
Reply By: Ray - Monday, Jun 30, 2003 at 15:08
Sorry
One more thing make sure you have the correct globe fitted
AnswerID: 23857
Reply By: Matt M - Monday, Jun 30, 2003 at 15:12
As said before, but the usual one is the earth on the dull light is bleep e!!
The only other earth it can find is throught the other light, ie through two filiaments, hence the dull light!!
If the excel uses the switch to switch on the positives then you are set and it is a case of just checking the earth and prob just a little corrosion, but if it doesnt and it switches on your earth, well goodluck.
From memory most switch on the positives, only older Nissans used to use the Earth system (not important dont need to be corrected if that isnt exact!!)
Let us know how you go!
Matt.
AnswerID: 23860
Reply By: Member - DOZER- Monday, Jun 30, 2003 at 16:12
Hi sometimes the parkers are in the headlights aswell, so the dull one might be a blown fuse, with the parker shining as bright as it can. Each headlight should have a seperatefuse under the bonnet.
Andrewwheredayathinkwer mike?
AnswerID: 23863
Reply By: RussellV - Monday, Jun 30, 2003 at 19:07
Ensure the mud is cleaned off after you've been out bush!! :)
AnswerID: 23879
Reply By: Ted G - Tuesday, Jul 01, 2003 at 13:01
I had the same problem with my wife's Subaru, followed all the usual advice and ended up taking it to an auto elec, who found the problem in 5 minutes.
It was the plug on the globe had burnt out inside, 2 new plugs, 1 new globe, a cup of coffee at the Golden arches while waiting and $60 out of the pocket and no dirty hands, problem fixed now good head lights.
Regards Ted
AnswerID: 23943
