Koolatron fridge anyone heard of them ?
Submitted: Monday, Jun 30, 2003 at 19:10
ThreadID: 5746 Views:3539 Replies:4 FollowUps:4
Obtained a Koolatron fridge the other day for free - has anyone heard of them they come from Canada - are they any good ?Cheers, Beddo
Surf KZN185
<- Yengo NP, Central Coast NSW
Reply By: Member - GOPE- Monday, Jun 30, 2003 at 21:13
Beddo,
Came for free, sounds pretty good to me. I'm in.
Happy days"Happy" :)>
AnswerID: 23893
Reply By: Mark - Monday, Jun 30, 2003 at 22:07
Beddo,
Would be interesting to see how well a Canadian fridge works in Oz. I spent a couple of winters over there and being a Pom my biggest problem was trying to warm the beer up !!
They do get hot & humid Summers though so I can see the need for a fridge then.
www.koolatron.com has some info. Sounds like an interesting concept no moving parts other than the fan. Have you tested the current draw ? uses thermoelectric apparently: In 1834 Jean Peltier noted that when an electrical current is applied across the junction of two dissimilar metals, heat is removed from one of the metals and transferred to the other. This is the basis of thermoelectric refrigeration. Would be great if it turns out to be efficient, please post your findings when you have been able to try it out.
AnswerID: 23901
Reply By: Bob Y. - Qld - Tuesday, Jul 01, 2003 at 06:49
Jeff,
Have had a Koolatron for over 20 years, and had no problems with it. Not that it has done much work lately. As Mark said they use Peltier Element, so are fairly "hungry" on power. Model we have has a thermostat, so can control use a bit. Are a good travelling fridge, but there are better options for camping.
Would make a good beer fridge, in the shed, as they can be hooked up to a power supply, or battery charger. We froze some veges in ours, not by choice. Hooroo...
AnswerID: 23920
Follow Up By: Jeff (Beddo) - Tuesday, Jul 01, 2003 at 20:57
Might just take it away to the Kimberley and use it on the oad to cool the beere before we set camp then we can put them in the esky. Only have a Evacool esky which is very insulated though putting warm beere in them soaks up the ice so the Koolatron might do the trick and hopefully won't drain the battery as I will be driving.Cheers, Beddo
Surf KZN185
FollowupID: 16113
Follow Up By: Bob Y. - Tuesday, Jul 01, 2003 at 21:44
jeff,
Koolatron should be okay for that use, and they are not very heavy, when empty. Think battery drain is supposed to be around 4-5 amps, so alternator will handle it.
It will keep things quite cool, while travelling. Also, if it carks it on the way, you haven't lost anything, just have to drink all the beer before it gets hot.
Safe trip...
FollowupID: 16119
Reply By: Member - Wherethehellawi - Tuesday, Jul 01, 2003 at 07:49
dont expect much more than say 20 degreees difference between ambient and interior of box. ie 30 ambient 10 inside, 35 ambient 15 inside, and as has per reply above they are VERY energy hungry. They cannot get stuff real cold either as the the colder they get the less eficient they become so expect the temperature difference to close eg ambient 25 inside 8 degrees. Just dont expect it to cool like a real fridge.
None the less have thought about making one for a lunch box while at work. One can use a sandard plastic insulated 6 can cooler box.Richard
AnswerID: 23921
Follow Up By: Steve from Drive Systems Victoria - Tuesday, Jul 01, 2003 at 20:29
Explains why he got it "for the right price", don't you think?
FollowupID: 16107
Follow Up By: Jeff (Beddo) - Tuesday, Jul 01, 2003 at 21:00
Sounds good for cooling the beers anyway - will give in a work out in the Kimberley leaving in couple of days - hopefully won't drain batteries when I'm driving as mine is an auto and that would be painful - I will need plenty of beere then - as long as the alternator is charging alright.
PS. My brother works at the local tip and thats where we got it - works Ok except one latch is broken.Cheers, Beddo
Surf KZN185
FollowupID: 16115
