AnswerID: 1526 Submitted: Tuesday, Dec 04, 2001 at 00:00
porl
replied:
What you have descibed would improve the efficiency of any 12V
fridge. I have a brand new CCF30L
waeco, by a keen eye and a lot of luck i noticed that the actual
fridge fits perfectly inside a styrofoam broccoli box which then again all fits perfectly into the box the
waeco came in. Another half a broccoli box and ten minutes with a
stanley knife and you have a top half that seals down on the bottom half of the broccoli box. The difference in current draw can be up to 15 amps over a 12 hour period. If i fixed a small fan, then given the Danfoss is after all a heat exchange unit, having a fax blow away the hot air would also i presume result in lower current draw again.
Reply 2 of 2
