Site Search
Section Image
gu wiring problem
Submitted: Sunday, Dec 02, 2001 at 00:00
eric
I have a 2001 gu 3.0 td, with driving lamps fitted. The relay is tripped off of the high beam so as to operate only when the high beam is operating and therefore legal. Seems to wrrk allright, with ample cable dimension, however I noticed that the fuel gauge is being affected ( shows low levels when actually full)since I have fitted the lights.I can't seem to find the problem and don't think that the high beam and fuel gauge would be using the same relay. Any solutions or ideas?? Thanks in anticipation.
Advertisement
ThreadID: 578 Replies: 3
Views: 599 FollowUps: 1
AnswerID: 1520   Submitted: Sunday, Dec 02, 2001 at 00:00
Peter Gordon replied:
Eric, check the earth wire(s)! Is it the same dimentions as the positive wire and does it run back to the battery? These two things can make an incredible difference. It is also a good idea to earth the relay to the battery directly using the same size wire (at least 4mm or preferably 6mm), depending on load. Let me know how you go. Cheers
Reply 1 of 3
FollowupID: 479   Submitted: Monday, Dec 03, 2001 at 00:00
Eric posted:
Thanks Peter, it was the earth wire from the relay causing the problem, wiring it direct to battery has fixed problem. Thanks again.
AnswerID: 1524   Submitted: Monday, Dec 03, 2001 at 00:00
sean replied:
I have same vehicle with rally 4000's fitted. I dont have any problems. Fuel guage is fine.
The relay is powered off a headlight plug adapter (no cut wires) and the lamps are powered and earthed directly to the battery.
If you wish to compare notes on our vehicles you can email me on sdavis@octa4.net.au
Sean
Reply 2 of 3
AnswerID: 1525   Submitted: Monday, Dec 03, 2001 at 00:00
eric replied:
Thanks Sean, you were on the right track with the earth back to battery, did this and fixed the problem. thanks.
Reply 3 of 3
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
Phone: 1800 21 21 21
