AnswerID: 24397 Submitted: Monday, Jul 07, 2003 at 13:31
Member - ADRIAN
replied:
CHECK POST 5355 REPLY 8
THIS DOES APPLY TO PATROL DONE HEAP S OF THESE DID ONE LAST WEEK
THESE ENGINES WILL DO MORE THAN 500K IF LOOKED AFTER.
THE ABOVE MAY BE PROBLEM COILD SAVE YOU HEAPS .OK PUMPS MAY COST ABIT
BIT NOTHING LIKE A REBUILD, AND YOU WOULD STILL HAVE TO REPAIR PUMPS ANYWAY HOPE THIS HELPS PS DONT USE BONAMY THAT WILL WRECK YOUR ENG. FOR SURE GOOD POWERFULL DETERGENT WORKS WELL WITHOUT WEARING OUT THE RINGS ETC.
INTERESTED TIO
KNOW HOW YOU GET ON dmech
Reply 4 of 5
FollowupID: 17269 Submitted:
Monday, Jul 21, 2003 at 16:25
crowe posted:
Adrian,
thanks for the advice, i read the post and have removed the return banjo bolt, there was a noticable blackness in the diesel and some slight staining of the bolt. Is there any more detail you can give me, what sort of price is it to get this fixed? can i just change the front oil seal and hope for the best rather than spending big dollars on the pump as everthing else is okay?
I have cleaned the bolt and recess, i will run it for a few days and see if the staining comes back.
cheers, crowe
FollowUp 1 of 2
FollowupID: 17556 Submitted:
Friday, Jul 25, 2003 at 01:01
Member - ADRIAN posted:
CROW
you will have to remove pumps from eng. to replace seal make sure that all t/marks line up etc [ on gears] seal only replacement is easy jus pry out old one press in new one might buy you some time,however shaft usualy wears as well on these units. seal cost about $9
parts to replace shaft /top cover seal/ gaskets /supply pump etc normaly about $200.00 labours a bit dear as you do need to know what your doing inside regards adrian
FollowUp 2 of 2
