Two way radio connection to aerial
Submitted: Saturday, Jun 07, 2008 at 09:20
ThreadID: 58467 Views:2871 Replies:3 FollowUps:4
Good Morning All,
I have an icom ic-40s two way, and have been given an external aerial being a Benelec 02635.
I need to find an adaptor that will connect the two.
I am located in Sydneys south (The Shire).
Would appreciate being sent in the right direction.
Thanks.
Reply By: TD100 - Saturday, Jun 07, 2008 at 09:43
Try Jaycar or Dickys for starters or you might have to find a major communications company to find your adaptors,i can not remember what is on the back of an icom unit,either screw on " UHF,TNC" or BNC i would have thought, you should be able to find something fairly easily i suspect. cheers Paul
AnswerID: 308300
Follow Up By: ynotme - Saturday, Jun 07, 2008 at 09:55
Thanks Paul.
The aerial reciever on top of the radio is threaded inside and out.
Will try your suggestions.
FollowupID: 574162
Reply By: Affordable Batteries & Radiators - Saturday, Jun 07, 2008 at 10:08
Kyle Communications. Link
Expensive little adapter.
AnswerID: 308307
Reply By: ynotme - Saturday, Jun 07, 2008 at 10:15
"Expensive little adaptor" ?
Can you expand on your comment ?
AnswerID: 308310
Follow Up By: Bonz (Vic) - Saturday, Jun 07, 2008 at 10:32
AD98FSC is the adapter serial no
take a look HERE
ANT J-CONNECTOR FOR IC-40S / IC-41S H/H FOR EXT USE - AD98FSC
Product Code: CONN ICOM J-IC40S
5 Available. Price: $39.60
FollowupID: 574163
Follow Up By: ynotme - Saturday, Jun 07, 2008 at 11:03
Thank you Bonz,
At least i now know what i am looking for and the cost.
FollowupID: 574168
Follow Up By: ynotme - Saturday, Jun 07, 2008 at 11:06
Sorry,
I should acknowledge your initial comment.
It is an expensive little adaptor.
Thanks again.
FollowupID: 574169
