Seeking GPS Advice please!!!
Submitted: Saturday, Jun 07, 2008 at 22:18
ThreadID: 58490 Views:4087 Replies:2 FollowUps:3
Just a short question in regards to Pq2 GO-710, 7"screen GPS from E-Bay (China) running Route 66 on SD card. Is it possible to run Shonky Map loadded on a separate SD card, and what software is required to read and use Shonky Map???
Thank you for your help
dedabato
Image Could Not Be Found
Reply By: Shaker - Saturday, Jun 07, 2008 at 22:41
What OS does the GPS use?
AnswerID: 308438
Follow Up By: dedabato (SA) - Saturday, Jun 07, 2008 at 23:17
Hi Shaker, As I don't know what OS stands for, I am posting following information and hoppe it will help you - to help me.
Thanks and Regards
dedabato
Product Details
Dimensions: 212mm(L)*117.3mm(W)*25.5mm(H)
Chipset SAMSUNG S3C2440A-40
Navigator firmware storage SD card or built-in NAND FLASH
Memory size 64MB
Video output type CVBS, PAL/NTSC identify automatically
Displaying screen size 7 inch
Receiving module Si-rf Star III
Signal channels 20 channels
Position accuracy 10m, 2D RMS 5m, 2D RMS, WAAS enable
Signal recapture time 0.1s on average
Update rate 1s
Maximum position altitude 18,000m
Video Format MP4, AVI, ASF, MPG/MPEG
Audio Format MP3, WMA, WAV, ASF
Picture Format JPG, JPEG, BMP, GIF
Power DC 5.0V 2A
Built-in antenna type Built-in power porcelain antenna
FollowupID: 574370
Follow Up By: Bonz (Vic) - Sunday, Jun 08, 2008 at 08:15
The OS is the operating system.
Judging by the specs above your GPS has a proprietary OS and wouldn't run Shonky or Oziexplorer.
FollowupID: 574392
Reply By: Member - Toolman (VIC) - Sunday, Jun 08, 2008 at 08:55
Without knowing anything about the Pq2 GO-710, 7"screen GPS I think it highly unlikely that you can use any other map than that provided with the device can be installed. Most PDA based in car navigation systems have the option of running other software butb devices such as Tom Tom Navman etc cannot.
Toolman
AnswerID: 308474
Follow Up By: Member - Graham H (QLD) - Sunday, Jun 08, 2008 at 13:57
I think to run Ozie etc you need a Windows operating system
Usually Ce or similar
FollowupID: 574503
