Driving lights
Submitted: Saturday, Jun 07, 2008 at 23:14
pf11
Hello, I was wondering if anyone here knows the correct way to mount a set of
Driving lights. As in is there any particular side that you mount the "Spreader Beam" and "Pencil Beam"?
Cheers: Phil
Reply By: tukka - Saturday, Jun 07, 2008 at 23:25
Spreader on passenger side and spotter on drivers side is the way most people do it, so that you get as much spread off into the bush as possible and
the spot beam can go as close down the line of your vision as possible.
308448
Follow Up By: ozwasp - Sunday, Jun 08, 2008 at 00:37
yep
574382
Follow Up By: Member - Bucky (VIC) - Monday, Jun 09, 2008 at 03:44
Tukka
Thats right mate !.
Set up the pencil beam right side, straight up the middle of the road, spread on the left side.
I have seen smaller lights, angled too the sides as
well, and when activated would be brilliant in the bush, for " seeing around corners "
Bucky
574692
Reply By: Bonz (Vic) - Sunday, Jun 08, 2008 at 08:19
I dont think it really matters. As setup is often a personal preference, I personally have two spot beams cause the cdread beam comes from the headlights with Plus50 globes in them, I find it works better.
In the high country I have "crossed" the lights so the righ hand light is pointed about 40 degrees to the left and vice versa, that way the lights show around the bends in the hilly country roads.
308467
Follow Up By: Bonz (Vic) - Sunday, Jun 08, 2008 at 08:19
ummm cdread = spread
574396
Reply By: DIO - Sunday, Jun 08, 2008 at 10:35
Personal preference. Don't forget to wire them through your high beam so that they switch off as you select low beam. Illegal otherwise for road use.
308487
