cruise control ap50
Submitted: Sunday, Jun 08, 2008 at 16:54
ThreadID: 58518 Views:3599 Replies:3 FollowUps:0
hi all,in trouble again so am calling on the club for some more valuable info,have an ap50 cruise fitted to our 80 series(18 mths),it has stopped working and have traced it to the speed sensor /magnet area,am wondering is it possible to wire it into the speed pulse generator already on the cruiser (back of transfer case),have tried to buy an spg147 but apparently not made anymore thanks all peter p
Reply By: V8 Troopie - Monday, Jun 09, 2008 at 00:58
I really doubt that, the instructions that came with my unit say nothing about other inputs.
Have you checked the brake and clutch switches? If the wiring there comes off (or switch goes faulty)the cruise control stops working.
My control stopped working once and only after I checked everything else I found the clutch switch had moved out of alignment. The speed sensor is pretty rugged, you could have lost the magnets but that would be obvious to see.
Klaus
AnswerID: 308688
Reply By: Member - Bucky (VIC) - Monday, Jun 09, 2008 at 03:26
I have had 2 of these fitted over the years, one manual, and the other electronic.
Had trouble with the vacuum actuator on the original one only, so I gave them a call on 02-9316 5033, if they are still there.
There is a test mode, that you can switch into at startup, (on either)
The Electronic one has been simply brilliant.
Sorry I cannot be of more help
Bucky
AnswerID: 308697
Reply By: Ann 40 - Monday, Jun 09, 2008 at 18:35
thanks for info and phone number will ring them,have traced problem to speed sensor on drive shaft so will replace them,thanks again,peter.
AnswerID: 308835
