Darkie has a new stereo installed
Submitted: Sunday, Jun 08, 2008 at 16:55
ThreadID: 58519 Views:2266 Replies:4 FollowUps:4
I finally have had time to remove the old genuine unit out of darkie and install a new single din unit and relocated the UHF into the opening while I was at it.
The question is what have others used to fill the space on the side of the units as I have about a 15mm gap either side of the stereo and UHF.
Cheers Sir Kev
Russell Coight:
Reply By: Member - Borgy.. (SA) - Sunday, Jun 08, 2008 at 17:12
Hi Kev,
My brother just put some black foam in the gaps... Looks quite good & if u didn't know, you'd think it was supposed to be there...
Cheers, Brad (Littleborgy on the old man's computer)
AnswerID: 308545
Follow Up By: Sir Kev & Darkie - Sunday, Jun 08, 2008 at 17:19
Little B
I was thinking along the same lines, it should mould pretty well to the unevenness of the side I presume.
Cheers Sir Kev
Russell Coight:
FollowupID: 574537
Follow Up By: Member - Borgy.. (SA) - Sunday, Jun 08, 2008 at 17:37
This is how the old man done his Kev
Image Could Not Be Found
Cheers, Brad (Still on the old man's computer)
FollowupID: 574543
Follow Up By: Isuzumu - Sunday, Jun 08, 2008 at 17:40
It is Darkie Kev not some little girls pink Hyundai hahahahaha
Cheers Bruce
FollowupID: 574547
Reply By: stefan P (Penrith NSW) - Sunday, Jun 08, 2008 at 17:23
When I removed the double DIN on the patrol, I placed one of those DIN sized trays under the new stereo and placed my UHF in that, but no good to you as it seems the original yota one is not a standard size.......I know how about you jam ya ego in there to fill the gap when QLD lose on Wednesday??? :):):)
Roachie used some plywood painted the same colour as his dash to fill a hole under his stereo, looked pretty good too.
Cheers Stefan
AnswerID: 308548
Reply By: Member - Nev (TAS) - Sunday, Jun 08, 2008 at 17:36
Hi there,
I cut a rectangular piece out of one of my empty black plastic oil containers as I had a black dash. I then cut it to fit over the UHF with a surround large enough to overlap the existing dash. I then used thin double sided tape and small screws to screw it onto the car dash and painted the screw heads black with permanent texta.
Looks the part even if I say so myself. I call it re-cycling!
Rgds
AnswerID: 308554
Reply By: Member - Vince B (NSW) - Sunday, Jun 08, 2008 at 19:05
Kev.
Tissues for wednesday night LOL.
Vince
AnswerID: 308588
Follow Up By: Sir Kev & Darkie - Sunday, Jun 08, 2008 at 19:07
What soI can hand them out to all the crying cockroaches LOL
Russell Coight:
FollowupID: 574579
