Fitting an Engle in an NM Pagero?
Submitted: Monday, Jul 07, 2003 at 14:25
ThreadID: 5856 Views:2456 Replies:2 FollowUps:2
Can anybody Suggest an easy way to fix an Engle 40L Fridge Slide down to the floor of an NM Pajero keeping in mind the Under Floor Storage Area!!!!! I spent far too much time on the weekend trying to find a decent solution.....
Keep It On The Rough Stuff
Matt (W.A.)
Reply By: lobinbundy - Monday, Jul 07, 2003 at 14:36
Matt Hi,
In my nm I fixed (existing anchor points) a sheet of 15mm ply cut to shape. I fitted my own frig slide to that and cut and hinged a trapdoor to give access to the under floor area.
Brutus.
AnswerID: 24401
Follow Up By: Matt (W.A.) - Monday, Jul 07, 2003 at 14:42
Thanks for that, sort of had the same idea didnt want to add any extra weight if poss. Does the 15mm ply span across the whole cargo area? how heavy do you recon it is?Keep It On The Rough Stuff
Matt (W.A.)
FollowupID: 16408
Reply By: lobinbundy - Monday, Jul 07, 2003 at 14:57
Yes it fits the whole cargo area from the cargo barrier back. I don't believe it weighs any more than the third row seats I took out.
Brutus.
AnswerID: 24403
Follow Up By: Matt (W.A.) - Monday, Jul 07, 2003 at 15:08
Good Point,
I'll do the same, thanks for your help.Keep It On The Rough Stuff
Matt (W.A.)
FollowupID: 16410
