2H oil pressure
Submitted: Monday, Jul 07, 2003 at 19:03
ThreadID: 5861 Views:2455 Replies:5 FollowUps:1
G'day troopers,
Can anybody out there tell me what the oil pressure on a 2H diesel
should be?
Cheers.
Reply By: Member - Robert (WA) - Monday, Jul 07, 2003 at 19:24
THE BOOK SAYS 250 KPA TO 590 KPA AT 3000 RPM
HOPE THIS HELPS
ROBERT
AnswerID: 24414
Follow Up By: The J - Man - Monday, Jul 07, 2003 at 21:09
Robert,
Thanks lots for the info. I have a "Gregorys" manual and it falls
short with this. What book have you got?
Cheers.
FollowupID: 16423
Reply By: Member - Robert (WA) - Monday, Jul 07, 2003 at 21:29
toyota workshop manual
AnswerID: 24428
Reply By: Member - DOZER- Monday, Jul 07, 2003 at 22:08
common problem with these motors is high oil pressure caused from a siezed main relief valve. If this is the case, get it fixed b4 it blows off the filter.
Andrewwheredayathinkwer mike?
AnswerID: 24430
Reply By: The J - Man - Monday, Jul 07, 2003 at 22:25
Thank you all very much. Your answers have helped.
stay safe,
J. J.
AnswerID: 24431
Reply By: Phil G - Monday, Jul 07, 2003 at 23:11
Second problem is that if the oil pressure looks low on the gauge, its usually because the sender on the 2H has lost its calibration.
AnswerID: 24436
