AnswerID: 1542 Submitted: Thursday, Dec 06, 2001 at 00:00
Patrick
replied:
Hi Ian - I had a simailar question on this site back on 24 October and receieved some interesting
feedback.
In my case I was looking at a Thumper unit to power my
Waeco 52 litre
fridge because at that time I understood that a 2nd battery system could not be installed in my Pathfinder. I subsequently found through an aftermarket dealer in
Brisbane that I could. The 2nd system cost $650 which was for an Parnaha tray with an Optima deep cycle battery plus 2x 6amp cables to connectors in the rear. The Thumper alternative was $700 - $750 and I found through the advice received that it would only run my
fridge for around 24hrs before charging would be required. The charging process is very slow and could take up to 18hrs to conmplete.
There were plenty of people who said that they liked the Thumper but I also spoke to extremely experienced off-roaders and a couple of local 4wd shops who said that they are more suitable to low ampage use rather than powering a
fridge.
A normal Danfross 35 condenser can use up to 4 amps per hour when the conditions are hot so it does not take much to draw down a 48amp battery. Remember that you have to allow for a cut off at around 20% of that.
I believe that after all the advice I received that my decision to install the 2nd battery sysyem was the more practical and cost efficient way for me for the future.
For more info try doing a
search of Exploroz.com by simply going to the
search option, typing battery packs of power packs and up it come.
Best of luck
Reply 3 of 3
