75 series troup carrier 1992 cluch
Submitted: Saturday, Jun 14, 2008 at 11:27
Member - COLIN D (VIC)
Is there a better replacement cluch to use other than a Toyota cluch , something extra good , or just go with the genuine ?
I have had an after market cluch fitted once before aprox 3 years ago , it now rattles on idle .
please help before i go with an original .
Colin
Reply By: qubert - Saturday, Jun 14, 2008 at 11:39
they make a 'heavy duty 'clutch, the same as they use in the turbo 6's . i dont know if this will help. i wouldnt be concerned about the rattle, they will all eventually do it. the sides of the clutch plates rattle against the housing , maybe a stronger pressure plate will help but all the heating and cooling will give the spring less tension and let the plates rattle anyway.
just a thought, maybe i am wrong, just something to consider.
309879
Reply By: Rock Ape - Saturday, Jun 14, 2008 at 12:16
Stick with the genuine, they are a good clutch, remember to have your flywheel machined when and if you change the clutch.
I am running the original clutch on my 89 troopy and that is with the extra torque of the 6.5l chev diesel.
Have a safe one
309888
Follow Up By: Member - COLIN D (VIC) - Sunday, Jun 15, 2008 at 13:05
I think that could be the go , thanks for that .
Colin
576101
Reply By: BarraKing - Saturday, Jun 14, 2008 at 15:25
Colin,
I have been told that Exedy make some great clutch units (Safari 4x4 range)
have attached there web address,
http://www.exedy.com.au/
Regards,
Josh
309922
Reply By: Member - COLIN D (VIC) - Sunday, Jun 15, 2008 at 13:03
Thanks Josh , had a look at the web site , looks good.
Colin
310087
Reply By: Member - COLIN D (VIC) - Sunday, Jun 15, 2008 at 13:07
Thanks for your advice , i,ll probably go with a Toyota one .
Colin
310088
