Jayco Swan Wind Up repairs
Submitted: Saturday, Jun 14, 2008 at 15:42
dndwest
Hi All, Had a bit of an accident with the wind up mechanism on our Jayco Swan. One of the clips was not undone and it seems as though the winding cable has snapped in the back right hand corner. Does anyone know how to repair this??
Reply By: allan b - Saturday, Jun 14, 2008 at 16:23
Gday there, Had the same problem ,take your time and trace cable through ,measure old cable length plus a bit more ,I bought cable and swages from marine
shop,borrow swage tool from same
shop,adjust up at winch end. Looks difficult but pretty easy when you understand the system . Let me know how you go. Regards
309936
Reply By: Member - Wayne B (QLD) - Sunday, Jun 15, 2008 at 11:56
I tried and had no joy,got Arrow at Chermside,
Brisbane to do it for me, admittedly $200+ but they serviced and replaced another cable that was also on the way out. You will find the cable run easy to do it is where it slides into the telescopic poles to be the fun part, easy once you know how.
310073
Follow Up By: Member -Pinko (NSW) - Sunday, Jun 15, 2008 at 14:10
We had a 1993 jayco swan. Sold it in 2001. Two cables broke at
mitchell plat. because the nylon guide pulleys at each corner had collapsed allowing the cable to rub on the locating bolt and also the guides to the rear of the camper. could not get it repaired in any small town only in capital cities.
Bought a tent in Kunanurra and lived outside for the following two weeks return to
coffs harbour. Jayco quoted $500.00 for the repair. I managed to jack the roof up in stages to the full height. I removed all the cables and pulleys. Went my local trade
shop with the broken and undamaged cables and the guy laid them on the floor then made new ones of identical length for $38.00 for the four cables. Then down to the ships
chandler and bought stainless pulley sheaves . I had to pack either side of the sheaves with appropriate washers because the metal replacements were narrower. Fitted it all back together and adjusted the cable length at the whipple tree and it worked a treat All up $55.00 and about a full day to do the work.
Stan
576108
Reply By: Member - Wayne B (QLD) - Sunday, Jun 15, 2008 at 15:16
Well done Pinky
310100
