I want to get tracklogs of my navagational aid
Submitted: Sunday, Jun 15, 2008 at 16:12
ThreadID: 58807 Views:2542 Replies:3 FollowUps:4
Hi all,
I have a Mio gps for which I have quite a few track logs on. I want to get the information off and email some of the information. I also want to save some of the tracks so as not to loose them. Anybody have any ideas how to do it. I can not find any info in the instructions and can not find anything in the articles.
Do I need Ozi Explore and match the mio up to it?
Thanks in advance
Reply By: Member - Graeme W (NSW) - Sunday, Jun 15, 2008 at 16:21
I can't help directly, but you could try the Online Q&A link on the Mio website. I've used it before and got a response in a couple of days.MIO
Graeme
Lake Eyre 2011
AnswerID: 310119
Reply By: Tim - Stratford (VIC) - Sunday, Jun 15, 2008 at 19:36
Peter,
If the track logs were made using OziCE then they should be somewhere on your PDA saved as a file.
I use a Dell and save the track log each day when out and about. I generally save it to the CF card and I think it defaults to that day's date.
All I do is sync the PDA to the laptop and then find the file on the PDA (through 'my computer' on the laptop) and copy it to the laptop.
...hope thismakes sense...
Tim
AnswerID: 310169
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 15, 2008 at 19:48
Thanks Tim, It does make sense. Unfortuanetly I do not have a cf card in it. I think it does use CE but when I hook it up to the laptop and go to "my computer" it does not register there is a hard drive there. Although the program that came with the mio recognises it is there. I can not understand how to do it :(
peter
FollowupID: 576208
Follow Up By: Skippy In The GU - Sunday, Jun 15, 2008 at 19:51
When usung Ozi-Ce the tracklogs are stored in the data folder , I prefer to use a card reader and just copy and paste to the PC
FollowupID: 576211
Reply By: richard - Sunday, Jun 15, 2008 at 19:52
Do you have an SD card then?
If you have an active synch session with your comupter you should be able browse the PDA from you PC - I can then do a cut and paste.
What tool are you using for navigation.
Rich
AnswerID: 310176
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 15, 2008 at 20:24
It is an sd card type but no I do not have an sd card in it. I can not find the pda in my computer either
FollowupID: 576219
Follow Up By: richard - Sunday, Jun 15, 2008 at 22:02
If you go the the disk list via explorer the icon used looks like a PDA.
If you zoom in there you will see another PDA icon - take that one and it is the PDA files.
This has to be done while linked to the PC via Activesynch.
I just installed the new version of OZICE - it is vastly different to the one I have been using.
In the doco for this new version from v2.14 ( the new version is 2.19)
2.14 - IMPORTANT CHANGE - The binary waypoint file and track tail file are now always stored in the "Data" folder immediately attached to the "OziExplorer 2" folder. In previous versions they were stored in the "Data File Path" which is a folder specified by the user in configuration. This is necessary to ensure the waypoint and track tail file are always available to OziExplorerCE. If the user specified a "Data File Path" on a memory card and then changed the memory card the waypoints were no longer available which is not desirable. If you have the ceWaypoints.wpb and ceTrack.trb files in a different folder manually copy them into the Data folder.
FollowupID: 576243
