80 series gearbox swap to 75 series
Submitted: Sunday, Jun 15, 2008 at 21:04
ThreadID: 58825 Views:9376 Replies:4 FollowUps:1
G day all has anyone or does anyone know if the 75 series box fit into the 80 series?. I think that the 75 box is alot better i have an 80 series and a 75 series that i am going to wreck so i thought i might try and do the swap and suggestions
Reply By: Aussie.Nomad - Sunday, Jun 15, 2008 at 22:14
Try the toyota owners site ..http://www.lcool.org/index.html
AnswerID: 310218
Reply By: Member - DOZER- Sunday, Jun 15, 2008 at 22:43
A big step backwards, if you think the 80 box is worse, then put some castrol vmx-m oil in it and that will make it shift better...the 75 box is known to have weak 5th and transfer idler...aswell as output spline problems, the 80 box only has shifting issues....
Wont fit straight in but will fit the motor...so thats 90% of the issues sorted....dribeshafts/crossmember and spedo to go
AnswerID: 310229
Reply By: autosparky - Sunday, Jun 15, 2008 at 22:43
depends on year. i am looking at new fdt v8 for my 80 series as a project and have had a look at suitable gearbox configs
AnswerID: 310230
Follow Up By: traveller2 - Monday, Jun 16, 2008 at 08:31
Put an auto behind it!
FollowupID: 576295
Reply By: howesy - Monday, Jun 16, 2008 at 10:39
Paste this into your browser. It is a slow site to load sometimes but it is a toyota forum and I seem to remember someone in the last week or so talking about converting from R151 to H55F gearbox.
http://www.4wdmonthly.com.au/forum/forumdisplay.php?f=44
Better still here is the post.
http://www.4wdmonthly.com.au/forum/showthread.php?t=55313
and here is the interesting statement check last 2 lines.
i have plans on the reverse conversion ..putting a 1hz onto my h55f in my 60
from memory the 1hz was on the 151 and the 150 transmissions in the 79 and 80 series
...But was also in the late 75 series
the 75 series had the 2h with h55f the upgraded to the 1hz on the h55f box
if to source a bellhousing from a 1hz/h55f 75 series cruiser you should be in buisiness..not sure about the cross member though!
AnswerID: 310292
