Dust in van
Submitted: Wednesday, Jun 18, 2008 at 18:01
Nomad 34 (WA)
We own a Coromal wind up van and have recently come back from a trip along the
Gibb River road. Each time we stopped for the night, we would find the van full of dust. There didn’t seem to be any dust on the bed and only a bit on some of
the bench tops, but around the stove there was plenty. I have included some photos, so you can see the amount of dust that came in. Can anyone tell me is this an acceptable amount or to much dust?
I seem to only be able to put one picture on the Thread.Image Could Not Be Found
Reply By: Nomad 34 (WA) - Wednesday, Jun 18, 2008 at 18:05
Another photoImage Could Not Be Found
310800
Reply By: Member - barry F (NSW) - Wednesday, Jun 18, 2008 at 18:35
There is a post on this subject just down the page, thread # 58899, might be of some help? Cheers
310810
Reply By: T-Ribby - Wednesday, Jun 18, 2008 at 19:02
Hi Nomad34.
It is possible to minimise dust entry but almost impossible to keep it out completely. We have a Coromal and a Camel campertrailer - the trailer has automotive dust seals and these certainly keep the dust out (smaller area helps of course). I would suggest some covers over your stove and sink, benches etc - old sheets are perfeck. It's not the ultimate solution, but it will help. I wonder if a 12v extractor fan would work?
cheers.
T.R.
310818
Follow Up By: Member - Kim M (VIC) - Wednesday, Jun 18, 2008 at 20:39
TR
I purchased a Camel Bushman around 9 months ago but haven't used it all that much due to work pressures. Hope to get away in the next three weeks.
Appears to me they are
well built with good quality canvas, but heavy to set up solo.
Think I'll just use it to cart fuel,
water, bit of gear and use the kitchen during over night stops (sleep in the car).
One of the things that gets my goat with all these CT's is the absence of internal tie down points to stop stuff being thrown around every where over corrugations and rough tracks.
That's the end of my tirade LOL
Nomad
In my experience there is nothing invented that will stop the ingrest of Bull Dust. Best thing you can do is tape a bit of cardboard over the outside vents and remove them at the
camp site.
Kim
576821
Reply By: Member - Garth J (NSW) - Wednesday, Jun 18, 2008 at 20:00
Noad 34,
What you need to do is create higher pressure inside the van than what is on the outside. Then air will be blowing out and dust will not be getting in.
This is the basic physics of things.
Air flows from a high pressure to a low pressure.
How this is done can be either mechanically ie ram air or electrically via using fans to compress the air so to speak.
In both cases you would require some type of filtering medium.
Also you should cover the vents that are in your van for the stove and I guess the fridge.
God luck
Garth
310837
Reply By: Nomad 34 (WA) - Thursday, Jun 19, 2008 at 12:26
Thanks all, the main thing it's not uncommon for dust to enter the van. I will look into reducing the dust with some of your ideas.
Nomad 34
310938
Reply By: bjb - Monday, Jun 23, 2008 at 16:47
Nomad
I also have a coromal PS 391 off road camper. I am interested to know how yours went on the
gibb river road as i will be taking
mine in a months time.Did anything break?
I have been travelling around
Darwin a bit over the last few months while working up here and dust is an issue with these, particularily as it is always red fine dust in the territory. I ensure now that i also wind up the roof clamps as tight as possible to pull the roof down so it gets a seal to the body.
I have found by putting additional seals on the push out kitchen and the travel door it has stopped 90% of the dust. Also
water as i have crossed some creeks about 950mm deep and found with the standard seals
water entered through the door onto the floor inside.
Have crossed
same creek again and no
water now and minimal dust.
311793
Follow Up By: Nomad 34 (WA) - Thursday, Jun 26, 2008 at 20:24
Hi bjb
We travelled around 1200km on dirt roads, the van went
well. Apart from the
Gibb river road we also took the van into the Bungles and Wolf
Creek with no problems.
I too put extra sealing around the slide out kitchen and around the travel door, I also blocked the fridge vents, none of this made any differents. The seal around the roof worked
well since there would have been dust on the canvas and there was none, I did notice the dust wasn’t going that high. Most of the dust was on the floor and in the cupboards near the wheel arch under the kitchen. There shouldn't be any problem with any dust on the GRR we bought it all back to
Perth. You will need some decent mud flaps, the plastic feet on the front support legs were demolished and the front boot has lots of chips in it not to mention the back of the 4wd. If you have a front and back bed awning and you don't think you will use them, take them off.
Mine were never used and covered in dust they were very hard to clean. Have a good holiday.
Regards Nomad 34
578397
