turbo and cv's
Submitted: Monday, Jun 23, 2008 at 16:54
ThreadID: 59116 Views:3100 Replies:7 FollowUps:3
2 questions in 1. Wanted an unbias opinion rather than asking a mechanic.
1. I have a GQ.2.8td with 240,000 on the clock. 80% of this mileage is off-road. I'm expecting to get 4-500K out of the engine but how long do I expect the turbo to last? How do i know when the turbo has 'blown'. Can I still drive but with less power. Dumb question to someone in the know, but I don't know!
2. After coming down off the crest of the dunes in the Simpson I was getting a 'thud' feeling coming into the steering wheel. My wife and I agreed it was coming from the front right wheel. There is also a bit of a noise on full lock (noise but no feeling into steering wheel). Is this the CV??
Thanks,
Reply By: Member - John (Vic) - Monday, Jun 23, 2008 at 17:02
When the turbo blows (If) then its pretty terminal with bits of turbo being sucked in the engine and you will know it.
The noise on full lock is it a clicking noise??
If so then its a CV.
The thud off the dunes could be the suspension bottoming out as you came of the dune crest.
Have you looked at the front suspension to see if its something obvious??
Otherwise get the car looked at by a good 4wd mechanic.
AnswerID: 311796
Reply By: Gossy - Monday, Jun 23, 2008 at 17:06
funny you mentioned the suspension bottoming out because thats exactly what I said to the missus (trying to put a good spin on it considering our isolation). Thats exactly what it did sound like though. Driving fine around town. I am confident my suspension is fine with new TJM shockers and the TJM coils are only about 3yrs old.
Turbo news is not good. If that's the case do people replace them before they die? If so at what mileage should I be looking at doing this?
The car is bullet proof and very happy with it so I have no problem in spending $ on preventitive maintenance if required.
AnswerID: 311798
Follow Up By: Member - Graham H (QLD) - Monday, Jun 23, 2008 at 17:28
You will know when a turbo blows. Huge clouds of white smoke usually. Turn it off cos if you dont it could suck all the oil into it and run on that till everything goes bang.
Usually once they are running on the oil you cant turn them off till it runs out.
Have had one go in a Scania bus and got it just as it started on the oil so we were lucky at over $30,000 for the motor
FollowupID: 577801
Reply By: madfisher - Monday, Jun 23, 2008 at 17:07
The noise on full lock sounds like a cv. It is very hard to predict how long a engine will last as it depends on service history and how it has been driven. 4.2s do huge ks but I have never heard of a 2.8 doing over 400000ks. Their are some 2.8 owners on this site and they would be more knowledgeable then me.
Cheers Pete
AnswerID: 311799
Reply By: Gossy - Monday, Jun 23, 2008 at 17:31
so how/when do I avoid this happening? Do I replace it now or wait for 300,000 or 400,000 km's etc?
AnswerID: 311807
Follow Up By: madfisher - Monday, Jun 23, 2008 at 17:42
I would talk to a turbo specialist, could be worth rebuilding before a big trip.
Cheers Pete
FollowupID: 577806
Follow Up By: Member - Oldplodder (QLD) - Monday, Jun 23, 2008 at 17:50
You should be able to get some one to check the free play in the turbo shaft.
Just had mine checked after 300,000k and still good.
Always used a turbo timer, which may have helped.
FollowupID: 577808
Reply By: Brian - Monday, Jun 23, 2008 at 20:06
Gossy,
I have no idea about the cv sounds, just an opinion on the turbo question.
To be honest I am fairly unfamiliar with the 2.8td, but with any turbo, the trick is keeping the oil to it. Oldplodder says above about a turbo timer, and they do have their place, personally I prefer a pyrometer, AKA an EGT guage. (Exhaust Gas Temp) With an EGT guage, I monitor the temp of the turbo, and am able to "cool" it when it overheats.... mine is a 4.2 GQ with an aftermarket turbo, it regularly gets to 600 deg C, but when I want to stop somewhere, I idle the engine for a few minutes till the EGT is down to around 150-180 deg C. This prevents the oil from "cooking" the bearing in the turbo. My mechanic has stated that i should rebuild by turbo, maybe next year or the year after, (it's 3 yrs old now), but as long as i cool it and monitor temps uphills and things, it will be fine.
Have heard that when they let go, they really let go!!!!!
Hope this helps,
Brian (Gold Coast)
AnswerID: 311875
Reply By: Member -Signman - Tuesday, Jun 24, 2008 at 08:25
Re turbo maintenance:
A trucky mate told me. Every now and again- after a hard run- before switching off, lift the bonnet, and with the engine idling listen for any "twinkle ticking" noise from the turbo. If so it's probably the blades contacting with the housing, bearings worn, time for an overhaul.
AnswerID: 311944
Reply By: Gossy - Tuesday, Jun 24, 2008 at 08:56
thanks all. I do service the car every 5000kms so I feel confident I am doing the right thing there. I also have a turbo timer. Hopefully with these two things good luck is on my side. Good idea about having a listen to it.
The reason behind my question was that when we coming down the Birdsville track the other week it was an absolute mess. We had to drive in High 3 for about 2hrs. Obviously this was hard work on the engine and turbo. One car from the night before had blown it's turbo (looked very new!) so I reminded myself that I would ask this question on my return. I made sure the turbo got a rest when I could (drive in a higher gear when not so muddy) to get the rev's below 2000 RPM.
AnswerID: 311945
