landcruiser 80 series sub fuel tank
Submitted: Monday, Jun 23, 2008 at 20:55
ThreadID: 59140 Views:9446 Replies:2 FollowUps:0
Hi, i have a fault with the controller on my 80 series sub fuel tank tank pump, when you press the button to transfer fuel nothing happens, and found out that the control box thats mounted in the rear guard is stuffed, so i hooked up power to the solenoid and fuel pump and all works fine. what i would like to know is if set this up with power through a switch can i continue to use it like this with no problems. any help would be much appreciated. Thanks Mark.
Reply By: autosparky - Monday, Jun 23, 2008 at 21:14
the controller in the rear guard is a relay , and yes you can control with your switch , make sure it's fused
AnswerID: 311892
Reply By: Member - Matt M (ACT) - Tuesday, Jun 24, 2008 at 08:57
Mark,
Would probably work OK, just need to watch that you don't run the pump dry otherwise you will be up for a bit more for repairs. The other thing to remember is that the fuel pump runs for 30 seconds or so on start up to ensure that fuel in the sub tank gets used. No biggy if you use it regularly I suppose.
Why not try to get a relay from the wreckers? Few people wrecking 80s on E-Bay at the moment as well. Contact one of them and you may get a replacement for a reasonable price.
Matt.
AnswerID: 311946
