coleman retro malfunction
Submitted: Tuesday, Jun 24, 2008 at 08:48
oz doc
Hi Everyone, bought a Coleman Retro 'tilly' type flouro light 6 months ago. Great light but has now developed a problem. Turns on ok then stops after a few minutes. Is fully charged. If you keep turning it on/off it will light up again, but then stops. Anyone come across this problem? Trying to avoid having to return it as I'm a bit remote and want to use it
camping in the near future.Thanks. Oz doc
Reply By: Member - Lionel A (WA) - Tuesday, Jun 24, 2008 at 09:38
Hi Oz, having the same problem.
Its the switch.....does it feel loose or sloppy ?
Lionel.
311958
Follow Up By: oz doc - Tuesday, Jun 24, 2008 at 09:47
Hi Lionel - does feel a bit loose on the high setting. Snug on the low setting. Have you sorted yours?
577933
Follow Up By: Member - Lionel A (WA) - Tuesday, Jun 24, 2008 at 14:46
Sort of....both settings on
mine were sloppy, just turned the switch till it felt snug. Stays on most of the time.
Had it for a year and a bit, probably not worth returning
mine now.
Cheers.....Lionel.
577964
Reply By: Member - Crazy Dog (QLD) - Tuesday, Jun 24, 2008 at 14:11
Hi OZ DOC!
If it is 6 months old it should be in w'tee. Why not just take it back for a new one...
Grrr!!!
312007
