Landcruiser HZJ Extended Brake LInes
Submitted: Wednesday, Jun 25, 2008 at 18:39
tukka
HI, does anyone know how much
suspension lift you can get aaway with before you have to add extended brake lines? Is it 3 inches or more? Thanks
Reply By: Member - Tony B (QLD) - Wednesday, Jun 25, 2008 at 19:13
Have a look at SNAKE RACING site looks like all lifts above 3" need the lines. regards tony
312222
Reply By: Middle Jeff - Wednesday, Jun 25, 2008 at 19:23
Hi Tukka
Over 3 inches, but if you car is getting on then it is a good idea to renew your break lines and they are not expensive and easy to do.
Have fun
Craig
312225
Reply By: Member - 120scruiser (NSW) - Wednesday, Jun 25, 2008 at 20:19
I have just done a three inch lift on my 80 and with the axles hanging at full extension the brake lines are still OK. You can't play the banjo on them yet. So probably over 3 inch you will need them.
312227
Reply By: Rossco td105 - Wednesday, Jun 25, 2008 at 20:21
G'day Tukka,
As others say 3 inches is the limit. When I went to four inch lift you could see the brake lines on their limit on the chassis hoist (wouldn't like to test them when articulating in the real world).
Ross.
312229
