Very Happy
Submitted: Thursday, Jun 26, 2008 at 08:12
Chambo
Hi all,
I've got a 2000 GU 4.2T and yesterday had the 3" system, dump pipe, boost tweak and dyno done by PGS in Mornington. The before dyno run produced 74kw at the
wheels which is one of the better ones. Apparently they can be between 65-75. After it was all done it has improved to 96 and boy what a different beast to drive. Thats a 30% increase and it pulls very strong from 1800 to around 2900 and the torque increase is significant. It will be interesting to see if the economy has been improved. To say that I am a very happy chappy is an understatment. I also have a MAV which is fitted with the 4500 petrol/gas and the oiler would give it a run for its money I reckon, not in the top end but where it matters. Cheers, Chambo
Reply By: Dave(NSW) - Thursday, Jun 26, 2008 at 11:20
Chambo,
Mine has the same set up you should have figures like this and that's only because I kept the fuel cut back a bit.
Cheers Dave...Image Could Not Be Found
312318
