Gu3 Nissan 3 Litre 2 3/4 inch Exhaust 2004
Submitted: Thursday, Jun 26, 2008 at 14:59
GregF
Howdy All. Gunna get one off the above sent over and fitted here, all inclusive top to tale. has any one got the same and are they happy and what improvement occured . I live in the Alice. so its a bit hard to go across to
Beaudesert to have a spit if its no good. Thanks for for any feed back
Reply By: Bob Y. - Qld - Thursday, Jun 26, 2008 at 17:07
Greg,
Put a 3" system on an 80 series some years back. Pondered about how the bloody hell a thing as big as that was going to fit, but it was no drama.
We have an after market rear
tank fitted, and the original pipe was rubbing it slightly. Took it back & they spent a few hours on it, no charge!
Reckon you'll be satisfied.
Hooroo,
Bob.
312357
Reply By: Member - Wayne57 (WA) - Thursday, Jun 26, 2008 at 17:19
Put one on my 3L 2007 Patrol, fantastic
312358
Follow Up By: Member - Graham H (QLD) - Thursday, Jun 26, 2008 at 18:27
Have just got home from having a 3"mandrel bent exhaust fitted to my 100 TD along with a Dtronic chip ($900 on Ebay brand new)
Certainly makes a difference.Standard dyno was 145hp with both fitted 165.2hp.
Is a DTS system fitted by AMMS at Sandgate in
Brisbane. Aluminised steel $1100 for fitting and 3 runs on the Dyno.
Excellent job and only took about 2 1/2 hours
Dyno results below
Red =standard
Blue =with chip only
Green= with both
Image Could Not Be Found
578351
Follow Up By: Member Carree (WA) - Friday, Jun 27, 2008 at 15:26
Hi Wayne
I am down in Bunbury (usually, in
Darwin at moment) where did you get your system from and if I can ask $, did you get or need to get 3'' dump as
well. I have new common rail 3lt and was told no need to upgade exh but I think it may help. Thanks
578516
Follow Up By: Member - Wayne57 (WA) - Friday, Jun 27, 2008 at 20:59
Hi Carree
I also have the new common rail 3lt.
I got 2½" dump and from the dump all 3" with a straight through muffler and no cat converter.
Sorry cannot remember how much I paid for it, it was ordered and installed by Mandurah Mufflers.
If you ever want to go on a day trip try www.westernpatrolclub.com a very good club with lots of trips around Dwellingup and Harvey area.
Wayne
578594
Follow Up By: Member Carree (WA) - Saturday, Jun 28, 2008 at 11:46
Thanks Wayne
I will contact mand/mufflers when I get home home and will also have a look at the patrol club. Thanks again, may see you on the road.
Take Care
Carree
578663
Reply By: Member - Bob K (QLD) - Thursday, Jun 26, 2008 at 21:44
Greg,
Fitted one a couple of months ago and just love it! Was easy enough to fit and
well worth the money. Huge difference when towing.
bob
312434
