toyota hilux sr 2005
Submitted: Friday, Jun 27, 2008 at 22:19
ThreadID: 59279 Views:15194 Replies:3 FollowUps:6
Hi all looking at purchasing a Toyota hilux sr 2005 dual cab, has anyone had any trouble with these Ute,Even though the towing limits 2250Kg will it tow a 16ft jayco pop top
Reply By: Member - Olcoolone (S.A) - Friday, Jun 27, 2008 at 23:15
Over all a good ute, our Hilux has to have the gearbox pulled out soon to find a rattle and a new clutch put in under warranty.
The Hilux's have a bit of a week clutch.
Picking up dirty fuel in the D4D diesels can lead to a $6000 to $10000 repair.
A few have had rear wheel bearing fail and there is a very intermittent engine fault that makes the Hilux go into limp mode.
Don't take this the wrong way but other 4X4's have worse issue then what I mentioned above.
There are no common engine, diff, transmission, suspension, steering or electrical faults known.
Try and get one still under Toyota warranty.
I would suggest a 2 inch suspension lift as they are a bit low in the front end and fitting a secondary water separation fuel filter before the main filter/pump.
Make sure it has a limited slip diff in the rear as not all SR's came out with them.
Try and find one with only one center latch for the tailgate, some came out with one on each side and others came out with one only like the SR5....lot easier to use.
If you can budget for a bit more get a late 2006 model as the specs where updated.
Regards Richard
AnswerID: 312660
Follow Up By: Member - Warfer (VIC) - Friday, Jun 27, 2008 at 23:33
Dont forget to there were two models of Hiluxes in 2005.The KZN165 and the new shape Hilux....
I hope i hav it right lol
FollowupID: 578622
Follow Up By: Member - Olcoolone (S.A) - Friday, Jun 27, 2008 at 23:38
I hope he meant the current version.
FollowupID: 578624
Follow Up By: Member - Moo - Saturday, Jun 28, 2008 at 17:30
We are looking at the KUN26 model I hope this isn't the one with thoses problems.
Before purchasing it do we have the right to ask the car dealer to have these thng checked out
FollowupID: 578727
Follow Up By: Member - Olcoolone (S.A) - Saturday, Jun 28, 2008 at 17:54
KUN26 are the current model, why wouldn't you have the right to ask for a vehicle inspection.
Thats why it pays to buy one under factory warranty.
FollowupID: 578733
Reply By: Member - Brad B (NSW) - Saturday, Jun 28, 2008 at 18:25
Hi, I have a 2005 Toyota Hi-Lux 4x4 Turbo Dual Cab for about 6 months and I am towing a 23`5th Wheeler ATM2650 pulls really well its only done 55,000k`s but still have not had a problem.Brad
Image Could Not Be Found
AnswerID: 312746
Reply By: Member - Robin M (VIC) - Saturday, Jun 28, 2008 at 21:05
Hello Maria,
I have a 2006 SR5 DC D4D 4WD and I have until recently towed a 16'Windsor Rapid (almost identical weight to yours) with it, but never in 5th gear when cruising on the highway. It ran along very nicely doing about 2400 revs at 90-95 kph and it was quite frugal, even when carrying a full kit of camping gear. I was able to pass slower vans without any problems.
As for problems with the 2005 SR, I know that there is some potential for clutch problems. However, from reading posts to this forum and talking with a local Toyota mechanic, I suspect that some of the failures have been caused by the drive train being placed under too much stress. The Hilux is a lighter vehicle than the beefier Landcruiser which would be my choice for towing a heavy trailer or caravan. I have done 52K kilometres without any problems.
I treat my vehicle with care - no speeding whilst the motor is cold, no high revving, sensible use of the clutch when starting off and especially whilst towing; it's got a 2" lift and A/T tyres.
If I was a designer/specialist fixing minor problems with a Hilux, I would:
1) adjust the reverse gear ratio .. it tends to go too fast in reverse gear, which also makes for feathering the clutch when reversing a trailer or van.
2) redesign the handbrake ...it loses effectiveness and needs adjustment at almost every service.
3) improve the headlights ... they lack penetration.
4) install a larger fuel tank .... 76 litres is not enough when touring the outback.
5) add adjustable lumbar support to the driver's seat.
6) install switches for the annoying seat belt warning beeper and the open-door beeper. I have switched mine off !
7) beef up the mounting of the spare wheel .... it needs an additional cross bar between the chassis rails.
Hope this helps with your research.
Robin
AnswerID: 312785
Follow Up By: Member - Olcoolone (S.A) - Saturday, Jun 28, 2008 at 22:48
Have you had problems with your spare wheel mount?
FollowupID: 578809
Follow Up By: Member - Moo - Sunday, Jun 29, 2008 at 20:44
Hi Robin
I still have to wait for the delivery of my "new car". Im not a person who drives their car hard, infact when I did my 4WD course in my Hilux, the teacher kept saying "give it to her". Just didnt realise that a car could do that........Oh soooooo much fun.I will take the new "lux" on a 4WD advance course just so i know how to deal with the car
FollowupID: 578957
