Jackaroo Remote >$500
Submitted: Saturday, Jun 28, 2008 at 18:28
WDR
We have two remotes. One of them does not unlock (switch inside must be faulty) GM dealer quoted $500 for part only - Does anyone have any alternative solutions - Apart from the obvious - Use the key.
Reply By: Member - Warfer (VIC) - Saturday, Jun 28, 2008 at 18:50
Hiya
I had my second Berlina remote done here no probs and for under $100 !
Mister MINIT
Tell GMH to go jump at that price !
312753
Follow Up By: Member - Graham H (QLD) - Saturday, Jun 28, 2008 at 19:37
Got a new remote part of our Berlina key for $95 included introducing it to the car via a computer hookup.
Was done by the Holden Dealer in Caboolture Queensland
578750
Reply By: Member - Graham H (QLD) - Saturday, Jun 28, 2008 at 19:41
Forgot to say reason it wouldnt work was because a $2 battery went flat in it. When I get time I will solder a new battery in and see if it works. May be worth a look in your case if you know someone handy with that sort of stuff.
You need to split the case ( the black part) carefully. It is just a small circuit board with a 3v Toshiba lithium battery soldered to it.
Not rocket science by any means despite Holden saying you couldnt get the case apart.
best of luck
312763
Reply By: Member - Oldbaz. NSW. - Sunday, Jun 29, 2008 at 08:37
I opened
mine...small screw, replaced battery...works fine now.
....oldbaz.
312825
Reply By: mike w (WA) - Sunday, Jun 29, 2008 at 11:09
Like all the others, ensure battery is working, i that fails, go to an ato parky and they should be able to give you the details of a remote reseller and code, who may not even replace as if i is only a swich they may be able to repair and replace. I had one done for our magna and it was about $25 to replace the switch, new battery and make sure it worked.r. As stated previously, alot cheaper than the genuine lot.
312838
Reply By: Shaker - Sunday, Jun 29, 2008 at 11:11
If it isn't the battery, pull it apart & clean the PCB under the switch pad with contact cleaner or iso-propyl alcohol.
312839
