Suspension Feedback
Submitted: Sunday, Jun 29, 2008 at 14:30
onemore
Re: Range Rover
Suspension : How does one respond to articles directly i.e. the article on
suspension by Damien Baker, where one could possible receive an informed reply?
Reply By: Member - Rob S (NSW) - Sunday, Jun 29, 2008 at 14:42
Hi on this
forum you are best to fire away a few questions .
And sift through the replies,and try and sort out fact from fiction.
Or do a search on this
forum search eg : Range Rover
suspension.
Try google there are be a few land rover,range rover forums out there.
Rob.
312863
Reply By: Philip A - Sunday, Jun 29, 2008 at 16:20
As a contributor to both this
forum and the AULRO
forum, could I suggest that you are more likely to get answers from contributors with similar experiences from the AULRO
forum.
There are miriads of springs available for Range Rover Classic, ranging from standard height to 4 or 6 inch lifts.
MIght I suggest that you research what springs are actually on your car . The usual way they are expressed is in free length inches and lbs per inch of compression. It would help gretaly if you can tell what springs are on it. Then someone can tell you whether they are standard height or some other height. Yours will be more like a Disco 1 than a RRC as you will not have a load leveller
Without knowing how high your car is and what springs are in it, its hard to be specific, but remember without air
suspension it obviously does not "kneel" to get in.
Have a look at this site, which lists most of the major manufacturers offerings.
http://members.shaw.ca/jbarge/springinfo.html
Regards Philip A
312873
