Site Search
Section Image
Car Battery and 12 Volt Appliance Use
Submitted: Wednesday, Jul 02, 2008 at 22:14
Geoff1967
I'm a weekend camper in my small Mitsubishi Colt. I'm after an opinion on whether my standard car battery would be strong enough to do the following between Saturday night and Sunday morning:
1. Power my twin fluro light (1 amp draw, probably use for 2-3 hours)
2. Power my portable DVD player (1.5 amp draw, probably use 2-3 hours)
3. Power my car kettle twice for evening and morning cuppa (uses around 11 amps).
I've read the battery info at this website and still can't figure out where I stand or if I need a 2nd battery. Obviously I don't want to risk being stuck in the middle of nowhere with a flat battery...
Appreciate any feedback.
Advertisement
ThreadID: 59449 Replies: 10
Views: 1325 FollowUps: 1
AnswerID: 313529   Submitted: Wednesday, Jul 02, 2008 at 22:27
Member - Phil G (SA) replied:
My suggestion:
Use the fluoro, but turn it off when you don't need it, because stars are nice.
Leave the DVD player at home because you're camping.
Buy a $20 single burner butane stove (get them anywhere) - they are light, compact and work really well.
Your battery in the Colt would be no more than 40Ah. You could take a voltmeter and not use anything when you get to about 12.4V, and (fingers crossed) the Colt will start.
Mt Finke
Click Image to Enlarge
LandCruiser HDJ79
Reply 1 of 10
AnswerID: 313539   Submitted: Wednesday, Jul 02, 2008 at 23:11
Crackles replied:
You could probably get away with the light & DVD player running for a max of 3 hours if the car battery was at full charge. To be sure you could run the assesories through a low volt disconnect switch set to leave sufficient power to start the car.
When using the high power kettle simply run the cars engine at the same time.
Your needs probably suit the use of a self contained battery pack which could be charged on the way to camp then taken out to be used where ever you need the light/DVD/kettle. Takes the risk out of getting a flat starting battery.
Cheers Craig.........
Reply 2 of 10
AnswerID: 313541   Submitted: Wednesday, Jul 02, 2008 at 23:15
Nomadic Navara replied:
I reckon you would be OK for one night if you throw your car kettle in the bin. Use gas for heating as previously suggested.
Reply 3 of 10
AnswerID: 313543   Submitted: Wednesday, Jul 02, 2008 at 23:25
Mainey (wa) replied:
Geoff,
there is no real problems with the numbers and times you have nominated ** BUT ** if you over do it, your fully stuck, unless you can push-start the vehicle.
As a safety procedure put a $9.99 multimeter on the battery and if it gets below 12v run the engine for a few (10) minutes.
Mainey . . .
wake behind the Stacer 420 SeaHorse
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
Reply 4 of 10
Activities Index
Wine, Cheese, Chocolate, Champagne Safari Wine, Cheese, Chocolate, Champagne Safari
Hunter Valley - NSW
Enjoy a day of indulgence in the picturesque Hunter Valley.
Circus Workshop For Fifteen - NSW Circus Workshop For Fifteen - NSW
Sydney - NSW
Create and star in your very own circus!
Bongil Bongil Kayak Tour Bongil Bongil Kayak Tour
Coffs / Mid North - NSW
Journey with us into nature, kayaking the waters of the Bongil Bongil National Park.
Ripple Manicure and Pedicure Ripple Manicure and Pedicure
Gold Coast - QLD
Why not treat yourself to an express manicure and pedicure to make your nails look gorgeous!
Book Now - Things To Do
AnswerID: 313550   Submitted: Wednesday, Jul 02, 2008 at 23:55
Member - Royce replied:
This is easy. I've done it lots of times. We had a Colt.. and other little vehicles.
Use the 12 appliances... don't worry. Flatten the battery.
Just make sure that you are camped uphill, so you can roll start in the morning!
Cheers Royce
Mt Wellington Tas.... a long ago van.
Royce
Reply 5 of 10
AnswerID: 313562   Submitted: Thursday, Jul 03, 2008 at 05:58
Mike Harding replied:
As others have said; you'll probably get away with it - minus the kettle but my suggestion is for you to buy a small spare battery (about $40, Big W etc) ideally with the same lugs as you car. That way you're in no danger of flattening your main battery and you'll have a "get you home" spare in the event your main battery fails. An el cheapo charger will recharge the spare at home.
Mike Harding
Reply 6 of 10
FollowupID: 579629   Submitted: Thursday, Jul 03, 2008 at 09:04
T-Ribby posted:
Yeah I'd go with the spare battery as a backup.
I have an 18ah deep cycle SLA which recharges via an Anderson plug when travelling and this powers an 18w fluoro (_Affordable_Storage_Drawers.aspx 1.5a) for the night and then tops up when on the road.
T.R.
AnswerID: 313584   Submitted: Thursday, Jul 03, 2008 at 09:36
Gronk replied:
Get rid of the fluro and either use a gas light or a battery powered led light..
Limit the dvd player to just one movie..
As said before re; a small gas stove..
And if its a manual, always leave it somewhere where it can be push started..
Reply 7 of 10
AnswerID: 313589   Submitted: Thursday, Jul 03, 2008 at 10:37
ben_gv3 replied:
Why not buy a jump starter pack?
Even the smaller ones have a 17Ah battery, plus they recharge thru the cig socket, have a halogen light, won't drain your starting battery. Hell it can even jump start your car.
Pretty cheap too.
BTW, your cig lighter fuse is only 10A so you're kettle will trip it first time round.
Reply 8 of 10
AnswerID: 313638   Submitted: Thursday, Jul 03, 2008 at 16:42
Geoff,
I recall your Colt is a new model. It has EFI and the fancy electronics. I wouldn't be relying on a push start.
Mt Finke
LandCruiser HDJ79
Reply 9 of 10
AnswerID: 313641   Submitted: Thursday, Jul 03, 2008 at 16:57
Member -Dodger replied:
It's simple,
Just buy yourself a jump start battery pack as big in amps as you can afford. Then run your accessories from it and the next day plug it into the cig lighter to charge it up whilst driving.
All this was said previously and I agree totally, Plus the small butane stove is also the way to go.
Parked at Boroka Lookout
Give a man a fish and he will eat for a day. Teach him how to fish, and he will sit in a boat and drink beer all day.
Regards Dodg.
Reply 10 of 10
