Nissan GU TI
Submitted: Saturday, Jul 12, 2003 at 16:09
brian@thereadgroup.c
Just pick up my new Patrol TI had ARB fit a Twine showe, 200 k down the road all power was lost, looks like the hose came off the outlet from the heat exchanger and had similar problems really peeeeeeeeed offfffff truck back in the workshop untill monday, this one has been fitted along site the radiater and would seem that it is very hard to get at to check on hoses glad i was on the blacktop, any ideas where it is best to relocate.
10 Para
Reply By: Mick - Saturday, Jul 12, 2003 at 22:28
Just a thought - are you really that desperate for a shower? If you are you can get portable units that in no way impinge on the workings of your car!
24799
Reply By: Member - Bob L - Sunday, Jul 13, 2003 at 10:10
Brian
With 2.8 GU dual batteries etc had no room for heat exchanger, tried everything.
It is now safely bolted to a flange inside the alloy bullbar.Solved problem of running hoses with no kinks and all hose fittings are accessable.
Bob L.
24823
Follow Up By: 10 Para - Sunday, Jul 13, 2003 at 10:16
Hi Bob what a great idea thanks for that will get them to fix it on monday i hope there is enough room i have a arb steel bar and winch if there is it should be great because as you say one can then change the hoses if need be " or at least check on them " the car has only done 207 k and was 1 day old was i mad, thanks again
16705
Reply By: diamond (bendigo) - Sunday, Jul 13, 2003 at 13:51
gday brian.
is there any room on the firewall behind the engine.
i have a gq and plenty of room there easy acces aswell not sure if gu the same.
ps how ironic helton heat exchanger above your post.new job coming so no fraser this time:-((
24831
Follow Up By: 10 Para - Sunday, Jul 13, 2003 at 19:54
Hi Diamond
Afraid not the bloody thing is full can't even get a duel battery in although have a a few good sugestions such as under the door seal and behing the bull bar
16738
Reply By: Steve from Drive Systems Victoria - Sunday, Jul 13, 2003 at 15:14
Do your self a favour and relocate it to under the door sill along side the chassis, plenty of room for service/maintenance/etc, less cluter in engine bay.
24837
Follow Up By: Steve - Sunday, Jul 13, 2003 at 21:26
And then consider where to put the kitchen sink!! LOL
16748
Reply By: dave charlton - Thursday, Jul 17, 2003 at 10:35
I have
mine fitted to the firewall utilising an existing stud and threaded rivets which is factory fitted for placement of the intercooler. It has been to the cape and back with no issues with it coming loose. This is on a 4.2td ST wagon. Not sure of the TI setup but I do not think it would be an issuee.
If you want to e-mail me Brian I can supply a picture of it installed. It is a great accessory to have and the backup is second to none from John at Twine.
25181
