Tail gate interior light activation 100 series, NOT WORKING!!!
Submitted: Saturday, Jul 05, 2008 at 13:11
Member - Andrew (WA)
I have noticed that when I open the tail
gate on the cruiser my 'rear' interior light is not activating.
When I open either of the back doors it works.
Must be something wrong with the switch that activates it when the tail
gate is open...but...where is it? I can't seem to locate a button or anything that would do the activating...
Any ideas???
Reply By: age - Saturday, Jul 05, 2008 at 13:47
Mine does exactly the same thing. Every service Toyota look at it, fix it temporarily then it fails 2 days later.
Guess it must be crap in the switch (my old 80 series door swithes used to do it as
well - a spray of WD spray and they would work again).
Will watch with interest
A
313991
Reply By: SPRINT-GTO - Saturday, Jul 05, 2008 at 15:25
Post your question on the LCOOL website and they may know the reason for your problem???
314000
Reply By: autosparky - Saturday, Jul 05, 2008 at 16:46
the switch is built into the lock on the upper tailgte door. take the trim off and you will be able to see the single wire to it . the problem may be a broken wire in the rubber sleeving and grommet to the upper door. the reason the light works on other doors is because it (light) is picking the earth through one of the door switches.
it is not an uncommon problem .the wiring harness may have been pulled inadvertantly or to tight in manufacture
314011
Reply By: Member - V8Diesel (WA) - Sunday, Jul 06, 2008 at 10:10
Here's another weird 100 series problem.
My rear wiper only works when the back doors (not tailgate) are opened. Buggered if I can get that one sorted.
Any ideas?
314088
