New GMC 3220 UHF problem
Submitted: Saturday, Jul 05, 2008 at 18:02
wato35
Having difficulty setting up the UHF. Is there an initial setup procedure to activate the 40 channels? Scans through 40 channels but when using the manual channel selector only gets 2 channels. Can receive and transmit.
Reply By: wato35 - Saturday, Jul 05, 2008 at 18:08
Sorry, should have said GME
314025
Follow Up By: Member - Graham H (QLD) - Saturday, Jul 05, 2008 at 18:40
What does the manual say
580087
Reply By: wato35 - Saturday, Jul 05, 2008 at 18:45
only how to actually use it. Not how the get it set up
314032
Follow Up By: Member - Graham H (QLD) - Saturday, Jul 05, 2008 at 20:07
I have a UNiden but it went straight out of the box. Have u got a button pushed that shouldnt be like CTSS or something that is stopping it from manually selecting. Make sure you have scan deactivated
580100
Reply By: John R (SA) - Sunday, Jul 06, 2008 at 10:18
None of the GMEs I've dealt with have a setup proceedure. I don't see that the new ones should be any different (I'm used to the 3400, 3200, 4400, 4600, so all but the xx20 series).
You should be able to wire it in, and immediately access all 40 channels.
Take it back to the dealer.
314089
Reply By: Member - Bob V (QLD) - Monday, Jul 07, 2008 at 09:09
The 3220 needs power/earth and the aerial and goes straight away, no need to do anything else, I installed
mine about two months ago
Bob V
314216
Reply By: wato35 - Monday, Jul 07, 2008 at 12:12
Thanks to all.
Found out that the radio was faulty.
Took it back and we are now all go.
314233
