catch can
Submitted: Sunday, Jul 06, 2008 at 23:06
Member - morry H (WA)
have 4.2 deisel. Before I put turbo on ,had a slight blowby from the pcv . now with turbo on, i am still getting blowby with approx 1 tblspn oil every 1000 k's caught in air cleaner tray.
which is before the turbo.
To stop this oil mist from going into turbo, can i fit a catch can?
Reply By: Member - Matt (Perth-WA) - Monday, Jul 07, 2008 at 10:25
Sure can!! boom boom!
Seriously thats what all the ricers do but a better mod is to put a filter in the line that returns the oil to the engine sump.
I fitted this to my isuzu MU then to my Rodeo, its off a 4bd1T and the return line taps into the dipstick tube.
Works a treat and cleaned up the intake perfectly.
Matt.Image Could Not Be Found
You can see the return line (small tube) and the tee piece was used to tap into the rocker cover oil return line to the dipstick.
314226
Follow Up By: Tasrat - Monday, Jul 07, 2008 at 14:40
Hi Matt I'm interested fot my 3.0 Gu Patrol. So this filter is of a what!! and how often do you clean it.
Cheers Paul
580273
Follow Up By: Member - Matt (Perth-WA) - Monday, Jul 07, 2008 at 18:36
Its off a 4bd1T (3.9L TD isuzu) from an isuzu truck.
There is no need to drain it...thats what the drain tube is for...you simply need to plumb it into a retun line to the sump.
You could make one with a plastic housing and a few fitting that are the same as the pcv lines on your vehicle similar to a catch can. Just fill it with the course pot scourers and fit a drain in the bottom.
When the air passes through the oil collects in the scourers and drips down into the bottom and back to the sump.
Matt.
580303
Reply By: Louie the fly - Monday, Jul 07, 2008 at 19:53
If you search the archives I think you will find a thread on this. I reckon it was info someone got of the Patrol
forum. It was an interesting read and quite easy to do.
314288
