Landcruiser 100s Sahara Suspension Fix?
Submitted: Wednesday, Jul 09, 2008 at 16:12
ThreadID: 59612 Views:20231 Replies:7 FollowUps:4
G'day,
I recently purchased a 2006 Sahara to tow a heavy off road caravan around Oz. However when I hook up the van the hydraulic suspension reverts to "low" which is hopeless for the 3000kms+ of dirt I intend to cover. Toyota official line is that the car cannot take a ball weight in excess of 80kgs and I have purchased the wrong car - unbelievable!
Has anybody been through the same issue and found a third party solution. It doesn't help that I only discovered the extent of the problem at Gladstone Qld.
HELP?
Thanks,
Barry
Reply By: Member - Phil G (SA) - Wednesday, Jul 09, 2008 at 16:43
I think Member - John R fitted polyairs to overcome the problem on his Sahara. His member profile is Here but he'd be up in Innamincka at present.
Theres another thread here.
AnswerID: 314554
Follow Up By: Member - JohnR (Vic)&Kath - Wednesday, Jul 23, 2008 at 12:02
G'day Phil, back home and I guess I better make comment elesewhere on the tripping.
In the SD I had a leak in the Polyair tube while away where the fitter hadn't shrouded the tube properly coming through the spring tower and had a puncture. I have made comment below your post in regard to my decision today to boost the spring capacity but keep the Polyairs in place to load share rather then keep the bags close to maximum pressure. I believe the springs are a rated 20% load lift.
FollowupID: 582989
Reply By: RobAck - Wednesday, Jul 09, 2008 at 17:30
I have a client who replaced the air suspension with a TJM kit and it works very well. I know he had a few challenges bypassing sensors and the like but he seems to have succeeded. Not sure where it stands with warranty and insurance without an engineers certificate though.
The poly air bag in the rear coils is always an excellent option for towing. You could also check out the suppliers of replacement air suspension to see what they may have to offer
RobA
AnswerID: 314558
Reply By: Boobook2 - Wednesday, Jul 09, 2008 at 18:16
I strongl suggest that you speak to Darren McRae of Autocraft. Not many people know about this suspension but he definitely dies. He hs done quite a few Sahara suspensions, inc resetting the sensors and shockers and lifts, and he has had contact with US suspension people as the lift / lower is standard equipment in the US. I may be wrong but I am pressty sure the Sahara has standard like coil springs at the rear and torsion bars at the front. The lift or lower is done in the pump up shocker.
Anyway he will know. He is away on a trip till the end of July.
His email is
Darren McRae [darren@auto-craft.com.au]
Phone is 0409 513 549 however don't expect a response this month.
You will also find info on www.lcool.org forum go to members area.
AnswerID: 314577
Follow Up By: Boobook2 - Wednesday, Jul 09, 2008 at 18:17
oops "does"not "dies"
FollowupID: 580595
Follow Up By: Member - JohnR (Vic)&Kath - Wednesday, Jul 23, 2008 at 12:06
The upgraded springs are available off the peg from Kings Springs giving a 20% lift in capacity over the normal body plus load. Kings make springs for other suppliers I believe, around Australia.
FollowupID: 582990
Reply By: Member - Motley - Wednesday, Jul 09, 2008 at 18:17
Hi Barry,
I have a 2000 Lexus LX470 and I believe that the suspension system you have is identical. I tow a Bushtracker Off Road caravan which when loaded for a trip, goes a shade under 3.5 tonnes. I too got the "Low" indication the first time I hooked the caravan up. I queried it with Lexus and was told by the service guys that it meant that the load was too heavy for the adjustable suspension to be raised by the switch but that was all - not to worry about it because the suspension would still perform as designed.
Well, as of now, the Lexus has done 260,000 kms and I have towed that van across every state in Australia with about 40-50% being on rough dirt. We have towed the van about 80,000 kms and for most of that, the suspension indicator light was on low. I do use weight distribution gear and I run with a ball weight at around 200-250 Kg.
The suspension is stock standard and has not required any servicing.
If your suspension is the same as on my vehicle, I would recommend weight Distribution gear and don't worry too much about the indicator light.
Hope this helps.
AnswerID: 314578
Follow Up By: Member - JohnR (Vic)&Kath - Wednesday, Jul 23, 2008 at 12:23
Motley, I think travelling with the car on Low is asking for trouble as it is so close to the bump stops. Last week we bent a drawbar extension join in the Karavan doing just that - third party extension, mot a manufacturer fault. Four years ago we bent an axle hitting the bump stops - just $1100 to repair, I thought got off lightly.
The guy who fixed the axle said he repaired 10 Toyota axles to one Niissan. I wonder why if people don't heed warning lights as part of their defences. It does state in my Toyota manual that there is little suspension movement on Low and NOT to drive on it. I was also told it is just to get into low garages or allow people enter and exit easily.
How did I know the axle was bent those years ago? By looking behind and seeing the wheels were further apart at the bottom than the top. Hard to see in a wagon, but not with a tray removed. I wouldn't like to buy a car that has spent a lot of time on the bumpstops or the potential to do so
FollowupID: 582991
Reply By: Member - Clive G (NZ) - Wednesday, Jul 09, 2008 at 20:12
Hi Barry.
Have a look at thread No 55049 on this site. There is a bit of info there. It seems that Polyair or Coilrite air bags inside the rear coils are the quick and simple answer. It fools the system about the weight of the car. I have used Polyairs for some years with zero problems, but Coilrites are just as good.
A Weight Distribution Hitch is a quick fix but they have a catch. The factory system works on oil pressure in the shocks with the oil pump under the bonnet on the LH side (no air is involved). The system looks at the total weight of the car, not just what’s on the ball. This means that if you used a WDH with the van, all may be well. But if you took the van off for a side trip you may find your total weight still to high owing to the gear in the car and it will drop down again. Just what you need for a side trip up a rough track. With air bags fitted this problem does not occur because the bags live on the car and can be pressure adjusted to any situation to keep the car level (no warning light on).
As a bit of an aside, if you can afford the cost, weight and space carry a couple of spare shocks with you (genuine Toyota), one front and one back. These are special shocks and you are unlikely to get them over the counter outside the main centres. If a shock fails the system pumps all the oil out in a flash, the car goes into alarm mode and drops to the bump stops on all four wheels. Except the back if its got air bags. I’m not sure but maybe the car goes into limp mode as well.
Regards. CliveG (NZ)
AnswerID: 314605
Reply By: Timid Trekker - Wednesday, Jul 09, 2008 at 21:19
Thanks all,
I will be very glad if a set of polyairs fixes the problem. A Brisbane Toyota dealer said that polyairs are not compatible with the Sahara's hydraulic suspension.
I would also like to reinforce Allan's tirade from thread 55049 about Toyota. I thought I had done my research knowing a Landcruiser can tow 3500kgs which roughly means a ball weight of 350kgs but the Sahara (according to Toyota) sags to low with a ball weight of above 80kgs. There is nothing in their advertising to say that their top of the range vehicle is inferior for towing. Think Sahara, think Toorak tractor!
Thanks for the feedback.
Barry
AnswerID: 314623
Reply By: Member - JohnR (Vic)&Kath - Wednesday, Jul 23, 2008 at 11:56
Barry, I have just decided to fit a slightly heavier set of Kings Springs to our Landcruiser Sahara. The Polyairs were fitted when we bought it and the pipe fractured on our Simpson Desert trip just over a week ago. Just a sharp piece of metal or a stone I guess and the car travelled on the Low setting for a couple of hours.
Our Sahara has a steel step bar with a wheel carrier, drawers with food, fridge, recovery gear and compressor and stuff, yeh, water, sometimes extra fuel.
Travelling on Low means you can easily hit the bump stops and previous experience means a potential bend in something - axle or chassis. In our case the other day, part of the drawbar extension of the Karavan. Not the fault of the Karavan or it's manufacture but the Polyair deflation and a third party extension. All now fixed!
I have this morning phoned Polyair, Airbag Man and Kings Springs and the decision is to go with a slightly heavier spring, but continue with the Polyairs in a supporting role. The cost of the springs fitted will be under $300 and the AHC should operate pretty normally with a load. The theme of the message I got from airbag people has been to share the load between the systems rather than use Polyairs or another at 30psi - their maximum inflation rate.
AnswerID: 316733
