occassional very shakey start up for 1HZ motor....
Submitted: Friday, Jul 11, 2008 at 12:52
Rowen
Howdy folks, hows things?
good to see some wet stuff falling from the sky...
um, just a quick one.
On very rare occassions, my trusty Tojo 80 series with 1HZ motor shakes a little excessively for a second or so on start up before it smooths out. Any idea's?
Im thinking of checking the engine mounts/ bolts....
Ro
Reply By: Stu & "Bob" - Friday, Jul 11, 2008 at 13:02
Air leak in the fuel line?
Mine used to do that, but I discovered that when I replaced the filter coming from the rear
tank, I hadn't tightened up the hoseclamps in the right spot and consequently air was getting into the system occasionally. I replaced the hoseclamps and bits of hose, and problem cured.
HTH
314813
Reply By: Stephen M (NSW) - Friday, Jul 11, 2008 at 13:16
How long since the glow plugs have been serviced/ replaced ?? Only takes one not to be heating up properly and will run rough for a second or two. Any excess smoke on start up ?? Probably a bit hard to see when your sitting inside eh ?? My old lux was the same, one glow olug was a bit dicky but never worried about it. Use to just glow it twice on extremely cold mornings, (rare in
Sydney) Regards Steve M
314815
Follow Up By: stefan P (Penrith NSW) - Friday, Jul 11, 2008 at 16:05
bingo!! the patrol does it on the real cold ones as
well. Couple of seconds and its all good
580874
Reply By: Member - Hughesy (NSW) - Friday, Jul 11, 2008 at 13:34
G'Day Ro,
All the cruisers I have owned (1HZ) have done this at times also. Typically on a cold start and after it hasn't been used for atleast a few days.
I only drive
mine once or twice a month (thanks god for a company car ;) so first thing I do is use the fuel hand primer to push any air out of the system and that works 99% of the time.
Nothing to worry about though.
314816
Reply By: Member - Davoe (Yalgoo) - Friday, Jul 11, 2008 at 13:54
when i was working 2 weeks away sometimes on return while it would start fine after about 10 seconds it would run rough for a bit before smooting out
- dont see it as a problem. when you can jump in a vehicle that has sat there for 2 weeks and start it with the breifest flick of the key you know its a Tojo
314820
Follow Up By: Patrol22 - Friday, Jul 11, 2008 at 17:23
Bugger...just had to go out and check the badges on my truck. Can be sitting idle for months at a time and still start first hit ...let the glow plug light go out, wait 5-10 seconds more and off she goes. But...............it's only a 2.8tdi Nissan so there's got to be something wrong with it I guess.
580879
Follow Up By: Member - Christopher P (NSW) - Friday, Jul 11, 2008 at 17:53
Warning, warning
Blooody Nissan Driver Polluting a Toyota Article!!!
Warning, Warning!!!! Drives a diesel!!!! Ooops a Turbo!!!
Nah just all in good fun!!! Wouldn't rubbish a good vehicle or Driver!!!
580887
Follow Up By: Member - Nick (TAS) - Friday, Jul 11, 2008 at 18:01
Patrol22 may have it, once the light goes out, wait another 10 seconds as the glow plugs are still heating up(up to a minute) depending on temp. sender.Our cruiser likes a stab on the accelerator pedal just as you hit the key for instant starting if its been a few day since starting.
580889
Follow Up By: Bware (Tweed Valley) - Saturday, Jul 12, 2008 at 22:37
Hey Nick,
The owners manual for my 93 80series says to depress accelerator when starting. Always have and never had a problem.
581151
Reply By: troopyman - Friday, Jul 11, 2008 at 22:23
Change the fuel filter .
314895
