Speedo correction - how?
Submitted: Friday, Jul 11, 2008 at 21:08
ThreadID: 59688 Views:2581 Replies:3 FollowUps:7
Hi all,
Just fitted 285 tyres to the 'cruiser (105 diesel) and of course the speedo is now out by a few kph. I have heard that it is possible to have it corrected. Does anyone know whether this is correct and better still, is this something that I could do myself? Being electronic, perhaps there is some kind of potentiometer or other adjuster?? (wishful thinking, I know!)
Gerry
Reply By: Member - Royce- Friday, Jul 11, 2008 at 21:14
Mine's out now I run 33"s.
So I just have my Navman set on speed and have satellite speedo!
Works well.
AnswerID: 314875
Reply By: siukalo - Friday, Jul 11, 2008 at 21:16
Give marks adaptor a call, they can fix it.
AnswerID: 314877
Follow Up By: Member - Longtooth (SA) - Friday, Jul 11, 2008 at 21:25
Agreed, Marks Adapters have a 'match box' speedo corrector. I have one and it works perfectly and no guesswork involved or remembering to add/subtract the difference. Works for all tyre combinations on the vehicle. Check their web site.
FollowupID: 580918
Follow Up By: Member - Graham H (QLD) - Friday, Jul 11, 2008 at 21:40
You can also buy a kit from Jaycar for about $50 against Marks $150 or so
FollowupID: 580926
Follow Up By: GerryP - Saturday, Jul 12, 2008 at 19:00
Thanks Graham,
Their web site says they're out of stock, but I might pop in to see if they are getting more in. Sounds the deal.
Gerry
FollowupID: 581082
Follow Up By: Robin Miller - Saturday, Jul 12, 2008 at 19:10
Jarcar kit (later versions) are good to use now Gerry, if you don't mind building electronics things.
These types of things cause about a 1/2 second time delay in reading your speed but the versatility is worth it.
FollowupID: 581087
Follow Up By: Member - Graham H (QLD) - Saturday, Jul 12, 2008 at 19:12
Try one of the shops they may have one when the warehouse doesnt
To see if you actually need one use this It will let you set all sorts of settings and give you the spped difference
http://www.rims-n-tires.com/rt_specs.jsp
FollowupID: 581088
Reply By: Tasrat - Saturday, Jul 12, 2008 at 10:59
That's just the width,has your diameter changed as well. If not should be no difference.
Cheers Paul
AnswerID: 314945
Follow Up By: disco driver - Saturday, Jul 12, 2008 at 23:25
Tasrat
Without going into a major explanation about tyre size and
% aspects, the answer is Yes the diameter will have changed..
To explain a bit
If, say, your tyre size is 245.75.16, 245 is tread width, 75 is the aspest ratio (also known as tyre depth), (this is the percentage of the tread width) and 16 is the rim diameter.
So if you upsize to 285.75.16 from 245.75.16, the diameter will be increased (75% of 285 is greater than 75% of 245).
However, if you lower the aspect ratio to 65 or 70 the tyre diameter will not be changed by as much.
Hope this helps
Disco.
FollowupID: 581160
Follow Up By: Tasrat - Sunday, Jul 13, 2008 at 17:05
Thanks for that disco, I probably should have known that but always thought the 65/70/75 etc was just mm height.But when you think about (which I obviously didn't ) it makes much more sense.
Thankyou for your clarification
If you know anything about airbags as coil replacements I would be happy to hear it.
Cheers Paul
FollowupID: 581254
