battery / volts
Submitted: Friday, Jul 11, 2008 at 21:22
ThreadID: 59689 Views:3594 Replies:10 FollowUps:11
i have two 90 amp/hour batteries in parallel, showing on the volt metre was 12.7volts. after six days of usage the volt metre showed 11.3. now it may be a dumb question but how far will it drop before it gets to 40% or the save volt reading before i need to recharge the batteries?
cheers shane.
Reply By: Notso - Friday, Jul 11, 2008 at 21:46
You are past that point now.
Running the voltage down that low will damage the battery, do it too often and it's had it.
Most voltage cut outs operate around 11.3 volts so unless you voltmeter is wrong then there may be a fault in the cut out system.
AnswerID: 314888
Reply By: Member - Graham H (QLD) - Friday, Jul 11, 2008 at 21:49
As I understand it you need to charge them when they drop to no less that about 10.4 volts or risk damaging them.
Across the terminals is a no load voltage.
What you need to do is put the load on them then test them
AnswerID: 314889
Follow Up By: Member - shane (SA) - Friday, Jul 11, 2008 at 22:08
the 11.3 is with load, but the 12.7 is no load. what i don't understand is, you have a 12volt battery so why is it not 6 volts is the half, using the volts system. but saying that, if it went to 6 volts it would not run 12 volt things i think. so is the 10.3 or the 11.3 the lowest you can go without stuffing the batteries?
cheers Shane.
FollowupID: 580938
Follow Up By: Member - Mike DID - Saturday, Jul 12, 2008 at 19:46
It depends on the size of the battery and how current you are drawing at the time.
If you're running a winch, the voltage may drop down to 9 volts while the winch is running under load - but you may still have 50% capacity left in the battery. The voltage will rise soon after you stop the winch.
The voltage-vs-capacity tables are meaningless unless you take the voltage measurement several hours after you have stopped all charge or discharge of the battery.
FollowupID: 581103
Follow Up By: Member - Mike DID - Saturday, Jul 12, 2008 at 19:53
"the 11.3 is with load, but the 12.7 is no load. what i don't understand is, you have a 12volt battery so why is it not 6 volts is the half, using the volts system. "
- because batteries just don't work that way. If you've ever designed any battery powered equipment, you'll be really glad they don't work that way !
FollowupID: 581105
Reply By: oldtrack123 - Friday, Jul 11, 2008 at 22:29
Hi Shane
ONE good rule for lead acid batterries IS keep them as fully charged as posible.[12.6/12.7v with no charge ]
#2 do not discharge below 50/60% remaining capacity for long life[ approx 12,5v with no load & depending on load about 12 .2v onload]
IE WORK THEM BETWEEN 12.7V &12.2 V FOR BEST LIFE .
all reading @ battery terminls.
11.3 is close to FLAT, TAKING THEM THAT LOW WILL DRAMATICALY SHORTEN THEIR LIFE.
Do not let them stand not fully charged as they will sulphate up causing loss of capacity & shorten life
AnswerID: 314896
Follow Up By: oldtrack123 - Friday, Jul 11, 2008 at 22:54
Table is for wet lead acid batteries with no load & not on charge.
On load reading[ no charge] would be about ,2to .3 v lower on average ,but this depends on load.
The reading are battery readings , depending on where your voltmeter is connected you could get lower readings due to voltage drop in the wiring when on load.
IF YOUR BATTERIES ARE WET LEAD ACID checking with a hydrometer is the best way to check remaining capacitor.
100% 12.7
80% 12.5
60% 12.3
50% 12.2
40% 12.1
30% 11.9
20% 11.8
10% 11.7
FLAT 11.6
FollowupID: 580951
Reply By: Dunaruna - Friday, Jul 11, 2008 at 22:30
It doesn't work that way.
If these batts are AGM's, fully charged resting voltage should be around 13v, a 50% discharged AGM will read around 12 volts. If it gets down to 6 volts, it's usually scrap (but not always).
Keeping a DC battery charged and above 50% will ensure maximum life span.
AnswerID: 314897
Follow Up By: Mike Harding - Saturday, Jul 12, 2008 at 07:46
I'll tell you on Tuesday :)
Due to the failure of some complex and sophisticated electronic test equipment (read: Harding stuck the wire in the wrong hole!) I have just discharged a brand new medium capacity AGM to 1V7 and that, certainly, made its eyes water!
By Monday it will have received three days of low current charge to float level and I'll do a full discharge (with the wire in the right hole this time :) to see what its capacity is.
Mike Harding
FollowupID: 580974
Follow Up By: Dunaruna - Saturday, Jul 12, 2008 at 10:27
A neighbor 'found' a 90amp AGM buried under a heap of carp in his garage (he remembers putting it there 14 months ago with the intension of charging it - then promptly forgot!). The durst MM said 3.2v. I told him to take it down to the local batt shop and maybe he would get a few dollars for it OR give it to me and I'll have a play around and see what happens. I put it on a Ctek15 and set it on recon, 3 days later it load tested at 12.2v. I set it on recon again, when that cycle finished I set it on normal and let it go for a week before load testing again - 12.4v.
I know this it not the norm and I would not have believed it but for the test results. For the past few months it has been happily powering a bilge blower in a houseboat.
Speaking of failed test equipment, where do you source those little weird fuses inside MM's? Jaycar & DS look blankly at me when I ask.
FollowupID: 580989
Follow Up By: Member - Andrew (QLD) - Monday, Jul 14, 2008 at 15:35
{{Speaking of failed test equipment, where do you source those little weird fuses inside MM's? Jaycar & DS look blankly at me when I ask. }}
What brand of MM are we talking about?
Try an Electrical Wholesaler (haymans, ideal etc depending on which State you are in) as they usually stock them for popular brands like Fluke. Make sure it is the same rating though.
FollowupID: 581404
Reply By: Redeye - Saturday, Jul 12, 2008 at 07:16
Hi all,
Can anybody please tell me how you can determine the charge of a battery between fully charged and % flat measuring volts ?
The following link shows discharge curves of various cells. A lead acid battery starts at 2.2 volts (approx) when fully charged and is almost a constant voltage across the discharge curve until the final sudden drop when flat.
http://www.mpoweruk.com/performance.htm
All I can tell, because of the different Characteristic of cell construction is if a battery is on charge or being discharged when using a volt meter. Volts does not equate to % of charge.
Redeye
AnswerID: 314913
Reply By: Mike Harding - Saturday, Jul 12, 2008 at 07:55
About one year ago I made a post to this forum with some information gained from professional testing I am doing on AGMs - try searching on something like "harding AND agm AND 2%".
The basic rule for AGMs is... discharge them as little as possible before recharging.
They should not be taken below 10V5 (some manufacturers do spec down to 9V0 but this is specialised stuff - not for domestic use).
From memory of the figures I posted: once an AGM reaches 11V0 it only returns a further 2% of fully charged capacity before it hits 10V5.
At 11V5 it will return 20% of capacity before it hits 10V5.
Conclusion: it is never worth discharging below 11V0 and you should only go below 11V5 infrequently. In general try to recharge when the battery falls to about 12V0 to 12V3.
Mike Harding
AnswerID: 314917
Reply By: Affordable Batteries & Radiators - Saturday, Jul 12, 2008 at 09:31
We are often asked how do you know what power is left in a battery, condition or state of charge. (SOC)
Here is a simple graph that shows SOC vs. voltage.
Please note this is an average and there are slight variables that are effected by temperature and battery type.
AnswerID: 314926
Reply By: Gronk - Saturday, Jul 12, 2008 at 10:52
As the above graph shows....keep it above 12V ( no load or under load ) and you really can't go wrong..
If you are regularly going too far down past 12V, then you probably need more battery power ..
AnswerID: 314943
Reply By: drivesafe - Sunday, Jul 13, 2008 at 07:57
Hi Shane, your battery was around 10% capacity if you had an 11.3 volt reading with a load, providing that load is no more than what your fridge pulls while the compressor is running.
Your No-Load reading is next to useless because to get anywhere near an accurate No-Load leading your battery needs to be sitting unused for at least 12 hours and even after 48 hours you still need to factor in a 5% error margin.
As Mike DID posted above, using something like a winch, because of the high current draw, will give you a reading of something like 9 volts with a battery that still has a 50% capacity, but if you are like most people out camping and wanting to keep an eye on the State of Charge ( SoC ) of your auxiliary battery(s), do your reading while the fridge is running, because most fridges only draw a few amps while the compressor is on, you will get a much more accurate and instant indication of the SoC of your battery than you will ever get while measuring the battery in a No-Load ( Correctly known as an Open Circuit ) voltage measurement.
The voltages shown in the posts above are Open Circuit voltage readings and in all fairness, are next to useless for anyone trying to get an idea of the SoC of their batteries while the batteries are in day to day use while out camping.
The voltages below are the sort of readings you can expect to get while your fridge is running.
100% 12.70
90% 12.50
80% 12.42
70% 12.32
60% 12.20
50% 12.06
40% 11.90
30% 11.75
20% 11.58
10% 11.31
0% 10.50
As your battery voltage reading was at 11.3 and as Mike Harding posted above, you had very little capacity left.
One more point, many fridges, with an automatic low voltage cut out operation, will do so at about 10.5 volts and if you have ever checked your battery’s voltage after the fridge has cut out, it is not unusual to get a reading from 10.5 to well over 11 volts. Again, to get anywhere near an accurate idea of the true SoC of your battery(s) take your reading while the fridge is running.
AnswerID: 315064
Follow Up By: Member - shane (SA) - Sunday, Jul 13, 2008 at 10:53
Thanks drivesafe and others, i have a volt gauge in the van and monitor it while things are on, (load). basically we only use it for lights and water pump, 3x 20 led mi6 lights, 2x22w fluro's, 1x11w fluro(toilet) and one exhaust fan which is a computer fan about 120mm. some times run the fridge off them as well. we are very conservative with what power we use but would of thought they would have lasted a bit longer.
cheers shane.
FollowupID: 581206
Follow Up By: drivesafe - Sunday, Jul 13, 2008 at 12:01
Hi Shane, with the batteries you have, 6 days use averages out at a bit over 1 ampere of power consumption per hour which is not bad even with the small use you are giving the batteries.
Your only using about 25 amps a day.
FollowupID: 581217
Follow Up By: oldtrack123 - Sunday, Jul 13, 2008 at 22:43
POST #3 did say to take .2 to .3 volts of open circuit for
"ON LOAD" readings
Might add that AGM batteries have higher readings.
FollowupID: 581335
Reply By: oldtrack123 - Monday, Jul 14, 2008 at 15:02
Hi Shane
The problem with volt readings are:-
#1:- How accurate is the voltmeter ,I have seen errors of up to .5v[ halfvolt] with the normal expanded scale ones available from super cheap etc.A high accuracy digital meter is needed to read the small voltage variations involved.or you need to know what the error is on yours.
#2:- Where is the voltmeter connected, If it has it's own DIRECT connection to the battery[ unlikely],it will read bat volts both on load & noload.
It will most likely be connected to the battery via some load carrying wiring which WILL give an error depending on the current the wiring is carrying. ie A VARIABLE ERROR.
The on load voltage of a battery depends on
#1 :-The state of charge of the battery
#2:-The amps being drawn from the battery high amps causes a a lower reading WHILE THE AMPS ARE FLOWING ,LOWER AMPS WILL GIVE LESS DROP[ HIGHER VOLTS ] This is due to the internal resistance of the battery.
So you can see from this that the onload volts test is subject to a number of variables which would have to be taken into account.
In my opinion, apart from the open circuit reading taken after 24hrs @ noload & nocharge, the next best test is with a very light load, allowing for about .2 volts drop from open circuit readings.
It is however only an approximate indication of state of charge so maintain a safe margin for long battery life.I would not go below 12v preferably 12 .2 v.
If your batteries are flooded wetcell s ie have caps, then a hydrometer is the BEST available, to YOU. means of testing state charge ,& individual cells for possible faults developing etc
AnswerID: 315258
Follow Up By: oldtrack123 - Monday, Jul 14, 2008 at 15:27
Just a further point ,
The noload voltage of a battery slowly encreases after the load is removed for up to 48hrs. You will not over discharge the batts using the noload figures.
One other point is that a battery with a reduced capacity [ due to old age ,loss of active material , sulpahation etc] can still show by voltage readings that it is fully charged.
It is but only to its reduced capacity ie what was an 80a/h may now only be a 40a/h
FollowupID: 581403
