Airbags
Submitted: Saturday, Jul 12, 2008 at 10:55
Tasrat
Hi all, greetings from
Hobart (It's cold down here).
I'm thinking of a revamp of the GU patrols
suspension and I'm looking at probags and OME shocks all round. The bags give so much versatility with ride ht. weight distribution etc etc.
My question is is there anybody out there with this rig and what affects are there on road handling camber etc. What camber correction would you need if any as it would spend most of its time at the standard ht.
Cheers Tasrat (Paul)
Reply By: nsngood - Saturday, Jul 12, 2008 at 20:57
i presume you are only putting airbags in the rear of the vehicle?
if so and if it is going to stay at the standard height most of the time then i dont believe any wheel alignment concerns are going to bother you.If your wheel alignment is checked regularly and in spec etc then whats the drama??
I havent dealt with.... probags.... before but most bags installed correctly (and used correctly) wont affect alignment as you are remaining at the standard height. If you are looking for a permanent lift then i suggest you replace springs and shocks as a set and then add some bags in the rear for those extra loads..
315024
Follow Up By: nsngood - Saturday, Jul 12, 2008 at 21:03
I have a two inch lift in my gq with no airbags (although when the budget allows they will be installed). This lift is achieved through new springs and shocks, be aware that this mod will require in most cases for some aditional parts as the front and rear diffs will shift sideways slightly depending on
suspension type.I.E. most leaf springs NO most coil springs Yes.
581127
Follow Up By: Tasrat - Sunday, Jul 13, 2008 at 16:56
Thanks for the info. I was planning all four bags as the probags replace the coils entirely. It seems the advantage with this system is the infinite ability to adjust for load and the capability to raise
suspension up to 4" in a tough situation.
Your thoughts?
Cheers Paul
581250
Reply By: nsngood - Saturday, Jul 12, 2008 at 21:05
oh yeah The additional parts are called adjustable panhard rods.
315025
Reply By: graybo - Sunday, Jul 13, 2008 at 01:48
Hi Paul, airbags will work
well in your rear
suspension. Great place to buy is Trucksprings in USA. I bought some for my Pathfinder about 8 months ago, they landed here in 2 weeks from website order- Firestone brand & $134.00 delivered to my door. If they don't have your exact vehicle on their list, you can give diimensions of your coils & they will supply to fit. easy-peasy and a damn sight cheaper than local supply. cheers Don
315058
Follow Up By: Ray - Sunday, Jul 13, 2008 at 10:27
Yes I did the same for my l'cruiser from Trucksprings. Got a compressor and gauges and all. So I can now control the height of the rear of the vehicle from the driver's
seat. All up it cost less than $400.00 and delivered within five days.
I tow a 17'6" Jayco caravan
581202
Follow Up By: Tasrat - Sunday, Jul 13, 2008 at 16:59
The trucksprings sound interesting, do they sleeve inside your coils or as the probags do replace the coil entirely. The probags seem to allow great flexibility in ride ht and load balance.
Cheers Paul
581251
Follow Up By: Ray - Sunday, Jul 13, 2008 at 19:18
With coil sppring vehicles the bags go inside
the springs. With leaf spring vehicles they attach to
the springs. see:- trucksprings .com
581277
