reverse light
Submitted: Saturday, Jul 12, 2008 at 13:10
ThreadID: 59700 Views:2438 Replies:3 FollowUps:5
Would any kind person have a 3 way wiring diagram for an after market reverse light, Have done a search but can't seem to find anything.
Cheers Dave....
GU RULES!!
Reply By: Member - Graham H (QLD) - Saturday, Jul 12, 2008 at 13:41
What vehicle do u want it to come on only in reverse or what
Full info helps
AnswerID: 314957
Follow Up By: Dave(NSW) - Saturday, Jul 12, 2008 at 15:22
Yeah, Going on a Suzuki Sierra and want it as a reverse light as well as able to turn on & off independently as a work light thanks.
Cheers Dave...
GU RULES!!
FollowupID: 581031
Reply By: Louie the fly - Saturday, Jul 12, 2008 at 15:55
Probably wire it up the same way I just put a volt meter in for two batteries. That is, use a ON-OFF-ON switch. Take one wire from reversing light power and the other from battery. Centre terminal of the switch goes to the light. Should work, shouldn't it?.
AnswerID: 314968
Follow Up By: Member - Mark H (VIC) - Saturday, Jul 12, 2008 at 17:33
I've always used a relay and make sure it us FUSED! If you have a meltdown of sorts the fuse will blow. If you don't have one you could get smoke...
Mark.
FollowupID: 581055
Follow Up By: geocacher (djcache) - Wednesday, Jul 16, 2008 at 00:00
A fuse before a switch is no different to a fuse before a relay.
You don't need a relay to switch a worklight. There are plenty of switches around capable of switching one.
Make sure you get the right sort of lense - ie. proper worklight not just a driving light wired up as one. Switchable rear facing driving lights are illegal in some if not all states.
FollowupID: 581703
Reply By: Member - Luke (SA) - Saturday, Jul 12, 2008 at 22:42
There is a diagram in the members swap area on this site. I know because I put it there. Have a look here
Good luck
Cheers Luke
AnswerID: 315038
Follow Up By: Dave(NSW) - Sunday, Jul 13, 2008 at 09:21
Thanks Luke, I never thought of looking in there.
Cheers Dave...
GU RULES!!
FollowupID: 581190
Follow Up By: Member - Luke (SA) - Monday, Jul 14, 2008 at 20:55
No worries Dave. It is easy to over look the members swap pages and go straight to the forum, I do it to.
Happy wiring :)
Cheers Luke
FollowupID: 581466
