dual battery for ca and caravan
Submitted: Monday, Jul 14, 2008 at 12:02
ThreadID: 59755 Views:3465 Replies:6 FollowUps:4
I have a redarc system already installed to run the deep cycle battery in my caravan. Can I install another deep cycle battery in my 4wd and run it in parallel to the caravan battery or do I need to get another redarc isolator?
thanx Bob
Reply By: Member -Signman - Monday, Jul 14, 2008 at 12:20
Give Redarc a call..08 8322 4848
AnswerID: 315235
Follow Up By:- Monday, Jul 14, 2008 at 12:27
thanx signman - simple when you think of it
FollowupID: 581382
Follow Up By: Member - mel D (NSW) - Monday, Jul 14, 2008 at 18:42
I already asked redarc the same question and the answer is:
Hi Mel,
Yes you can charge the auxiliary in that fashion, but I wouldn’t recommend running a winch through a 100Amp Smart Start, you should really use the 200Amp Smart Start for that (SBI212).
If I can be of any further assistance, please do not hesitate to contact me.
Best Regards,
Dylan Pinkard
Customer Service Technician
FollowupID: 581422
Follow Up By: Redeye - Monday, Jul 14, 2008 at 19:24
Mel,
Good advice.
Redeye
FollowupID: 581432
Reply By: Member - Glenn D (NSW) - Monday, Jul 14, 2008 at 18:41
Hows it going Bob,
It will just be like charging a bigger battery . No worries .
Glenn.
AnswerID: 315299
Reply By:- Monday, Jul 14, 2008 at 23:15
thanx guys for all your prompt replies I'll let you all know how I go in a fortnight
AnswerID: 315342
Reply By: Member - Peter J (NSW) - Tuesday, Jul 15, 2008 at 19:47
It's not that simple. The batteries will endeavour to balance out if one is of lower charge than the other if the circuit is open. Also, if they are different types of batteries they will not charge consistently.
If you isolate them your secondary battery in the car will charge before the caravan thereby leaving the caravan charging last and maybe not being fully charged when you need it most.
My thoughts are definitely to isolate them but put a quick charger under the bonnet as a spare only and to be used last when the caravan battery is flat. Alternatively make sure the batteries are identical and be aware that they will balance up until fully charged.
AnswerID: 315484
Reply By: oldtrack123 - Tuesday, Jul 15, 2008 at 21:15
Hi Bob
the Redarc relay parallells the crank bat & the van bat AFTER the crank has charged to approx 13.2v. The alternator then continues to charge both batterries in parallell.
Adding a 3rd bat simply means you now have 3 bats in parallell.The batts should be the same type ie 3 wet lead acid or 3 agm , but need not be the same amp/hr rating, & you can mix crank & deep cycle. [use heavy 6sqmm cable not 6mm auto cable as a mininum between redarc & aux in 4by]
The main problem with your set up will be that the crank & aux in the 4by will be charged while the van battery will not be charged to the same extent due to voltage lost in the long run of cable to the van batt.THIS is COMMON PROBLEM WITH ALL VAN BATTERRIES UNLESS A SPECIAL CHARGER[OPEATING OF 12V] IS USED THAT BOOSTS THE VOLTAGE & CONTOLS THE CHARGING OF THE VAN BAT.
The only other way to minimise the under charging is to use the heaviest cable possible [ positive & negative] you can between the van bat & the Redarc relay
The 2 aux batts will equalise & discharge to the same level over time if in parallell .
AnswerID: 315508
Follow Up By: ajr - Wednesday, Jul 16, 2008 at 14:18
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
FollowupID: 581773
Reply By: Mainey (wa) - Tuesday, Jul 15, 2008 at 23:21
Bob,
Yes, you can install another deep cycle battery in your 4wd and run it in parallel to the caravan battery.
Alternator-> (CRANKING battery)-> Redarc-> (4WD battery)-> (VAN battery)
“Cranking battery” is fully charged first, causing Redarc to close the circuit, forcing all three batteries to be charged as ONE large battery.
Mainey . . .
AnswerID: 315533
