Landcruiser HDJ79 turbo diesel revving when depressing clutch
Submitted: Thursday, Jul 17, 2008 at 17:43
ThreadID: 59861 Views:20207 Replies:7 FollowUps:1
Hi everyone, I have a 2005 Landcruiser ute with the factory turbo diesel engine. When driving the car, the engine revs after depressing the clutch when changing gear (as if I had the accelerator pedal pushed down), there is no problem unless the car is actually being driven down the road. Has anyone come across this before? Somewhere in the back of my head I remember someone telling me what the problem is, unfortunately, I do not always have access to that part of my brain...can't remember the password hehehe.
Any help would be appreciated, thanks.
Reply By: Member - Phil G (SA) - Thursday, Jul 17, 2008 at 17:52
They are Drive by wire - so can't blame a cable!!
Is the accelerator pedal sticking, and not coming back?
As an aside, they do get EGR problems, and the fix is simple:
link here.
AnswerID: 315789
Reply By: Member - Captain (WA) - Thursday, Jul 17, 2008 at 18:19
Do you have the "heat" or "idle up" switch on?
Captain
AnswerID: 315794
Follow Up By: Member - John (Vic) - Thursday, Jul 17, 2008 at 18:30
Check the hand throttle make sure its wound in.
FollowupID: 581987
Reply By: Dunedigger - Thursday, Jul 17, 2008 at 18:26
Mine does it too. ( 2003 TD model )I have always felt it was because I did not take my foot off the accelerator pedal quickly enough. Perhaps it happens only when I wear my size 13 bluntstones instead of my thongs.
I suspect it could be related to pollution regulation emissions
Dunedigger
AnswerID: 315797
Reply By: Member - Royce- Thursday, Jul 17, 2008 at 23:07
Check the return spring on the throttle? Might have been stretched. Happened on my old girl once.
AnswerID: 315841
Reply By: autosparky - Thursday, Jul 17, 2008 at 23:15
it could be the same as in petrol throttle bodies get gummed up(waxes from fuel and oil blow by) and need a clean ?
AnswerID: 315842
Reply By: Member - Matthew C - Thursday, Jul 17, 2008 at 23:38
Ok if its the 1HD-FTE engine it is a TCV(timing control vlave ) fault in the pump.
Very common some can be done on the vehicle ,but normally requires the pump off to replace and recalibrate.
MAtt
AnswerID: 315847
Reply By: OzTroopy - Friday, Jul 18, 2008 at 19:36
Does the vehicle have a diaphragm in the fuel pump ?????.
Earlier model vehicles with such a setup and a torn or holed diaphragm exhibited similiar problems or worse.
AnswerID: 315930
