HF Radio Feedback
Submitted: Friday, Jul 18, 2008 at 10:42
ThreadID: 59881 Views:3508 Replies:5 FollowUps:2
I am a HF novice but looking at purchasing a HF radio either from ebay or by some other forum and after reading the article I need all the help I can get. Can anyone help me make sense of the options etc...?
Reply By: VH-GU4 - Friday, Jul 18, 2008 at 11:46
What is it exactly you need help with understanding???
AnswerID: 315888
Reply By: Member - Craig M (QLD) - Friday, Jul 18, 2008 at 17:21
I have one for sale if you are interested and have the room. A barrett 250. What specific info are you after?
Craig
VKS 737
Quebec 1770
AnswerID: 315921
Follow Up By: PoppyGee - Friday, Jul 18, 2008 at 17:39
Hi Craig M. This is where I show my novice. I assume the barrett 250 has sellcall / tellcall or has the capacity to have it installed. We would like to be able to phone home just in case. If it doesn't come with it and has the capacity how much would it be to install? The bit I'm not sure about is do you get the 5 channels listed by VSK737 when you sign up with them, do you need all of them and if you do and not have them, can they be added and how much? I have seen a lot of units for sale which say they have 2 VSK737 channels installed, others say lost of channels installed. This is my novice bit again. Are other channels needed? Finally ebay has a few that are around $700 and above, yet new ones are $3K to $4K. Is it buyer beware...but beware of what?
FollowupID: 582148
Follow Up By: Member - Craig M (QLD) - Friday, Jul 18, 2008 at 18:07
Do a search in the forums for barrett HF250 or Codan HF and spend some time having a read. I have both flavours and both have their pros and cons. It is a bit like the old Cruiser vs Patrol argument. Different people have their favourites.
HF is a bit more challenging than UHF to use. For a start you need to be licensed. VKS737 is a good place to organise this and a great bunch of people to have on your side when the wheels fall off. Then you need to carefully consider the installation location. Older HF's are the size of a tea tray and can pull 10 amps out of your battery when transmitting. Also, you need a spot to mount an antenna as well. It is much larger than the old UHF.
All that being organised, I can talk to Darwin and Adeliade from Townsville most days. It works where phones don't however I have never used the RADPHONE function. As far as channels go the early CODANs needed a PC to reprogram the EPROM to add channels however the barrett can have extra channels programmed via the front panel. Be careful buying a barrett 250 from WA via Ebay. Some of the are ex WA police and have had a board/chip removed from them prior to sale.
Have a read and see how you go. There are many helpful people on this forum who will help you out.
Craig
FollowupID: 582154
Reply By: Dave & Shelley (NT) - Friday, Jul 18, 2008 at 23:27
Hi mate,
What infromation do you require. I have spent some time researching this topic before buying my first HF. I now have upgraded for a bucket load of cash. If you need any particular advice, please give me an e-mail.
AnswerID: 315960
Reply By: Crackles - Saturday, Jul 19, 2008 at 14:54
Gaday Poppy. HF radios are a much more complicated than a regular UHF both to install & use & for that reason I'd suggest speaking directly with a salesman/radio tech to see what type of radio you need & what features it has to have. They often have 2nd hand radio's for sale.
For basic coverage the 5 VKS737 frequencies are a necessity as are the Radtel channels for telephone interconnect. Personally I find the phone system unnecessary for outback travel & the quality & reliability of the calls can be poor at times. The VKS network will give you excellent coverage, location reporting, messaging, weather reports & even have the ability to put you through the phone system in an emergency so even the cheaper 5 channel units with a simple tapped antenna is all one really needs in that case.
I asume you have already read ExOz's excellent Overview on HF?
Site link
The VKS Site is worth a read as well although doesn't get into specific radios.
Cheers Craig.............
AnswerID: 316028
Reply By: PoppyGee - Monday, Jul 21, 2008 at 09:05
Thanks for the your replies. I still have a lot to learn before I purchase one, and ebay has bargains, but you need to know what you are looking for.
AnswerID: 316293
