LED lighting
Submitted: Sunday, Jul 20, 2008 at 20:26
ThreadID: 59956 Views:4202 Replies:10 FollowUps:9
OT seeking help from someone smarter than me. i would like to start changing over the halogen 50 watt down lights to LEDs, some one told me the 12 volt transformers will not run the LED lights. can someone point me in the right direction, looked in jaycar cat. but have down lights but no mention of what transformers.
cheers shane.
Reply By: Robin Miller - Sunday, Jul 20, 2008 at 21:07
I don't know about the smarter than part Shane - but osram and others make a range of products that are more efficent than the 50w standard downlights, and are direct replacements.
The CFL version are most cost effective and led ones are getting better but are still dearer.
Here is an example
http://www.todae.com.au/comersus2/store/comersus_viewItem.asp?idProduct=582
AnswerID: 316234
Reply By: Member - Drew T (Melbourne) - Sunday, Jul 20, 2008 at 21:08
Have a look at Todae and especially LED Shop online. LED Shop Online has some good info on their site. Seems that typical 3W LEDs are only equivalent to about a 20W halogen although you can get some 5-7W LEDs (see below) which are claimed to be 85% the output of a 50W halogen. I haven't found a 50w equivalent LED yet.
I am running some 240v LEDs (warm white) at home but i would really need to double the number of light fittings before i put more LEDs in (and the cost of the LED globes is a limiting factor too!!). I have also used a single 12v MR16 "Galaxy 5-7W LED Down Light" from Todae in my Caravan annex & it is terrific (just so i had an 'overhead' light in addition to the van side light) .... it is claimed to be ".. the most powerful LED light on the market outputting about 85% of a 50w halogen". Cost me $90 just for the globe but it certainly is extremely bright & energy efficient.
Another consideration with LED lighting is that they typically don't achieve the beam spread that you get with incandescents & halogens.
LED Shop Online also has some good info about running LEDs from transformers
AnswerID: 316235
Reply By: Member - Craig M (QLD) - Sunday, Jul 20, 2008 at 21:10
I have them all around the eaves of my house. Standard electronic switchmode or iron core trannys will run them no probs.
They put out bugger all light though. Might be better looking at a Nelson MR30 or MR50 compact fluro. Will fit into a standard halogen downlight fitting although they run on 240V not 12v and will require the base to be changed. Buy one LED before you blow your cash and have a look. You might be disappointed.
Craig
Image Could Not Be Found
AnswerID: 316237
Reply By: Member - shane (SA) - Sunday, Jul 20, 2008 at 21:30
thanks guys, looks like its not going to be that easy.
AnswerID: 316245
Reply By: Dunaruna - Sunday, Jul 20, 2008 at 21:31
If the transformer is 12vDC it will run the LED's. Some transformers for halogens are 12vAC.
AnswerID: 316246
Follow Up By: Nifty1 - Monday, Jul 21, 2008 at 21:33
I can't believe you got away with that!
FollowupID: 582700
Follow Up By: Dunaruna - Tuesday, Jul 22, 2008 at 17:27
Got away with what?
FollowupID: 582827
Follow Up By: Mike Harding - Tuesday, Jul 22, 2008 at 18:49
Transformers don't work on DC.
FollowupID: 582858
Follow Up By: Dunaruna - Tuesday, Jul 22, 2008 at 22:18
Huh? Strange, I have 6 LED downlights in my eaves running off a DC transformer.
240v to 12vDC transformer
240v to 12vAC transformer
FollowupID: 582931
Follow Up By: Mike Harding - Wednesday, Jul 23, 2008 at 05:45
The first link appears to be a switchmode power supply with built in rectification. The second link is a transformer and will _only_ work with AC - both in and out.
A transformer works because the _changing_ current, as the mains AC waveform changes from 0V to +340V back to 0V and to -340V, in the primary winding induces a similar current in the secondary winding. If you applied a DC voltage to the primary a constant current would flow and, therefore, not induce a current in the secondary.
Mike Harding
FollowupID: 582944
Follow Up By: Dunaruna - Wednesday, Jul 23, 2008 at 08:05
Shanes concern was that his current halogen 'transformer' would not run LED downlights. Halogen downlights can be AC or DC, an AC transformer would not be suitable for LED's. IF his halogens are DC, his 'transformers' would be suitable.
I did not know that a DC power supply is not called a transformer, thanks for correcting me.
FollowupID: 582952
Reply By: Boobook2 - Monday, Jul 21, 2008 at 06:28
There are 7W LEDs coming out which are similar to 50W. $$$$$$
I heard that Nelson are currently testing 8W , 12V flouros that are MR16 and work with transformers. They are doing extended testing to make sure it works on most transformers. They are expected to be released later this year.
I would definitely wait for a while, it is too expensive now.
I replaced all the 50 W with 20 W at home and no one noticed!!
AnswerID: 316270
Follow Up By: Boobook2 - Monday, Jul 21, 2008 at 06:31
I should have mentioned, if you do this, you will notice 50W are easy to get for $1.50 ea but 20W are generally $5.00 ea. EXCEPT at IKEA of all places when they are 4 for $6.00 from memory. They are rebadged Mirabella.
FollowupID: 582561
Reply By: Mogul - Monday, Jul 21, 2008 at 07:58
All very interesting.
I have been toying with the idea of changing our downlights to these low wattage LED's and running them from a 12v battery with a panel on the roof. It would also mean no more dark nights thanks to Energy Australia.
AnswerID: 316279
Reply By: Sand Man (SA) - Monday, Jul 21, 2008 at 19:58
Shane,
Are we talking about downlights for a caravan, or home lighting?
I will assume home lighting as you have mentioned "off toplic"
If home lighting, get rid of those transformer based lights mate.
I was advised from my local Lighting Shop LED lights still have a way to go before they are as effective in brightness as the fluros.
I have replaced all of my 240/12 volt downlights with 240 volt fluorescent equivalents. The transformer type lights generate too much heat and are therefore potential fire hazards. They are also the most expensive to run in power consumption.
The 240/12 volt ones were rated at 50 watts each, compared with the 240 volt fluros of 14 watts each and don't generate much heat.
The best fluros to go for are the "warm light" ones. The others are just too harsh a light for indoors.
Bill.
Bill
AnswerID: 316393
Reply By: robak (QLD) - Wednesday, Jul 23, 2008 at 11:31
Shane,
I have read somewhere that LED's are no more energy efficent than flouros. It was previously thought that led's put out more light per watt but this was due to the concentration of the light coming out of LED's and you are wasting energy in transormfers as well. Flouros, in my opinion, give a better all around light.
AnswerID: 316729
Reply By: Andrew Main - Wednesday, Jul 23, 2008 at 18:22
Okey Dokey....
First thing to specify is what colour temperature you want? Normal halogen lights run around 3000 K (Kelvin) which is that nice warm white we're used to. Most LEDs unless otherwise specified are going to be cool white, 6000K+, similar to standard fluorescent tubes. If cold white is ok then go for it, there are quite a few down lights out-there in cold white that will be similar output to 50W halogens, have a look at Soanar and their lighting division:
http://lighting.soanarplus.com/products.php?group=P26&product=DL-S-W-W-36
Now if you're interested in warm white then the efficiency of the LEDs is going to be much lower. In reality probably around the same as a good quality halogen, the lifetime will be 10 times as long at least but the efficiency will not be great with current technology. Give it 1-2 years and probably yes but right now no.
To answer the original question then yes there is a problem with so-called electronic power supplies designed for halogens (SMPS), these are design to regualte properly between 20W-50W output and below this some can fail to regulate and result in flicker on the LEDs. Not all it just depends on each individual unit. Two from the same manufacturer can exhibit different properties. Iron core transformers are fine - make sure the LED module has inbuilt current control however or you'll blow them up.
Couple of points to mention to those interested:
The efficiency of an LED as released by the LED manufacturer has nothing to do with the final lamp efficiency, a LED may output 70lm/w (lumens/watt) but one you heat it it reduces in output and then once you put it through a collimating optic it reduces again. Final system efficiency is more important.
If a light has a narrower beam angle (i.e. more of a spot) than another lamp but the light on the surface is the same then the lmp with the narrower beam angle has less output. If you focus something down you can get more perceived brightness but it will in fact not be brighter, just more focussed. What's really important is luminous flux output or lumens, which is the total lamp output.
A standard halogen will have around 1000lm +/- 100lm output, an LED would need to match this to be equivalent. Right now some systems are capable but only in cold white. Warm white still needs some work.
AnswerID: 316786
Follow Up By: Boobook2 - Wednesday, Jul 23, 2008 at 19:06
Andrew ahh I think it is worth waiting till the price comes down. Those LED's are pretty expensive.
At USD140 ea ( say A$150) the following applies
Assume you use the lights 4 hours a day and you swap from 50W Halogen to 15W LED.
Electricity cost about 15c per KwHr. The power saving of using 35W less is 0.5c per hour.
That is 28,500 continuous hours of use, or at 4 hr per day is 19.6 Years before you are ahead!!
I guess they will be about $10ea in a year or so when volumes ramp up. At that point you will get a pay back of 1.3years ( and you will have used $7.66 of additional electricity while you wait for the price to go down).
I think warm or cool they have a fair way to go before they are economical.
FollowupID: 583060
Follow Up By: Andrew Main - Wednesday, Jul 23, 2008 at 20:23
A very fair point.
You also need to factor in the cost of changing over a LED vs. a halogen. A LED will last around 10 times longer than a halogen (possibly a lot more).
But regardless of the marketing hype LEDs are not a panacea of efficiency unless you really pick your LED and even then it will not be cheap right now. The main applications where they are finding favour at this sort of price is in difficult to change areas.
Compact fluros are the more efficient way to go in terms of bang for your buck but watch the cheap stuff as it tends to have a very low light output after only a few hundred hours. Go for Osram or Phillips.
FollowupID: 583082
